Hi
we want to use geoserver’s ability of producing pdf outputs for “high quality web printing” (something like this: http://www.john-longo.org/b1.pdf ). My problem is, that I get sometimes quite small pdf-files (around 300 kb) but also “too” big ones (above 1 mb: http://www.john-longo.org/b2.pdf ).
The only difference between the two is a really small difference in the Bounding Box. I was able to track down the following: the latter one has a small part of a very large street-polygon ( http://www.john-longo.org/a1.pdf ). Then I tried to request a pdf of only a part of this street ( http://www.john-longo.org/a2.pdf ) with the same width- and height-parameters in the wms-request. I expected that the pdf with the whole street will be larger than the small part… Far from it. 240 kb versus 490 kb. Why is a small part of a large polygon blowing up the pdf output?
Any ideas? Thanks.
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler@anonymised.com
http://www.so.ch
Ziegler Stefan ha scritto:
Hi
we want to use geoserver's ability of producing pdf outputs for "high quality web printing" (something like this: http://www.john-longo.org/b1.pdf ). My problem is, that I get sometimes quite small pdf-files (around 300 kb) but also "too" big ones (above 1 mb: http://www.john-longo.org/b2.pdf ).
The only difference between the two is a really small difference in the Bounding Box. I was able to track down the following: the latter one has a small part of a very large street-polygon ( http://www.john-longo.org/a1.pdf ). Then I tried to request a pdf of only a part of this street ( http://www.john-longo.org/a2.pdf ) with the same width- and height-parameters in the wms-request. I expected that the pdf with the whole street will be larger than the small part... Far from it. 240 kb versus 490 kb. Why is a small part of a large polygon blowing up the pdf output?
Any ideas? Thanks.
Not really. We are not generating the PDF by hand, but drawing on
a java graphics context provided by iText, the java pdf library.
To us it's no different than drawing on the screen or on a printer,
it's iText that is doing the pdf conversion.
We recently upgraded the version of iText we're shipping with to
cope with a rendering issue, so you might get different results
with it. If better or worse, I don't know... be sure the check
out GeoServer 1.6.0-rc2 next week and tell us how it's working
for you.
