[Geoserver-users] PDF Printing NullPointerException
After upgrading my GeoServer instance from 2.4.1 to 2.5.1, I installed the Mapfish printing plugin. I had it working fine (with the print-lib-2.0-SNAPSHOT-20140410.jar) before upgrading. Now when I request the info.json, I get a NullPointerException (see http://pastebin.com/gJWhADR1). What can I try to fix this? I followed the installation steps at https://github.com/geosolutions-it/mapfish-print/wiki. The contents of my configuration file are at http://pastebin.com/iw4AJtnF
Thank you!
Bettina Lechner
blechner@…6560…
Hi Bettina,
looking at your config.yaml, it appears truncated on pastebin.
I don’t if this is the cause of your issue (you are using a wrong config.yaml) or simply the pastebin is incomplete.
Can you please check and in case send us the complete file?
Thanks
Mauro Bartolomeoli
2014-06-11 21:00 GMT+02:00 Bettina Lechner <blechner@anonymised.com>:
Thank you!
Bettina Lechner
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
Geoserver-users mailing list
​Hi Mauro,
I don’t think it is truncated, it’s just a very basic config for now. From what I can tell based on the plugin configuration documentation, it’s valid though. Let me know if you see any issues with it.
Bettina Lechner
From: maurobartolomeoli@anonymised.com84… maurobartolomeoli@anonymised.com on behalf of Mauro Bartolomeoli mauro.bartolomeoli@anonymised.com
Sent: Thursday, June 12, 2014 3:32 AM
To: Bettina Lechner
Subject: Re: [Geoserver-users] PDF Printing NullPointerException
Hi Bettina,
Thanks
Mauro Bartolomeoli
2014-06-11 21:00 GMT+02:00 Bettina Lechner <blechner@anonymised.com60…>:
Thank you!
Bettina Lechner
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
Hi Bettina,
I did some more checks, I think there is some sort of bug in the yaml parser. Your Yaml seems to be correct, but it seems section completely empty (such as !legends) are not correctly parsed.
I tried adding a configuration property after !legends (backgroundColor: #FFFFFF) and the parser seems to work again.
Please try and let me know. In case you can try to open a issue on github (or I can do it for you if you don’t know how to do it).
Mauro Bartolomeoli
2014-06-12 15:28 GMT+02:00 Bettina Lechner <blechner@anonymised.com>:
​Hi Mauro,
Bettina Lechner
From: maurobartolomeoli@anonymised.com <maurobartolomeoli@anonymised.com> on behalf of Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com>
To: Bettina Lechner
Hi Bettina,
Thanks
Mauro Bartolomeoli
@mauro_bart
@mauro_bart
Thank you!
Bettina Lechner
Thank you! That is indeed a workaround. I opened a ticket it GitHub: https://github.com/geosolutions-it/mapfish-print/issues/20
Bettina
(402) 554-2088
Hi Bettina,
Mauro Bartolomeoli
2014-06-12 15:28 GMT+02:00 Bettina Lechner <blechner@…6560…>:
​Hi Mauro,
Bettina Lechner
From: maurobartolomeoli@…84… <maurobartolomeoli@…84…> on behalf of Mauro Bartolomeoli <mauro.bartolomeoli@…1107…>
To: Bettina Lechner
Hi Bettina,
Thanks
Mauro Bartolomeoli
2014-06-11 21:00 GMT+02:00 Bettina Lechner <blechner@…6560…>:
Thank you!
Bettina Lechner
blechner@…6560…
@mauro_bart
@mauro_bart
