[Geoserver-users] Performance and feasibility using geoserver if map publishing is.s. done using shapefile or oracle spatial database
I have a huge amount of Vector data that I would like to serve via
geoserver, data size would be around 300 GB covering an area of 1/5th of the
U.S.
There are around 60-70 odd layers and all this data, I would like to serve
via WMS and there are SLDs to be applied to the layers for roads,point
symbology using SVGs.
Question:
1. I can create shape files(.shp) for this data or put it into oracle
spatial , which one would give better performance if we publish via Oracle
Spatial datastore or publish via Shapefile datastore for all these vector
layer. I understand that shape file has a limitation of 2GB,I will somehow
manage to restrict the size to 2GB or increase the layers.
2. We have around 25-30 concurrent users as well on this and would increase
in future, what would be better(shp or oracle)
3. Do we really need tile caching for these vector layers or we can bypass
it and serve directly from geoserver at all the time if we use shape file?
4. Are there any Oracle connecting/buffering tweaks on Geoserver recomended
for these kind of large datasets.
Kindly suggest.
best Regards
dk
View this message in context: http://osgeo-org.1560.n6.nabble.com/Performance-and-feasibility-using-geoserver-if-map-publishing-is-s-done-using-shapefile-or-oracle-spe-tp5035558.html
find my 2 cents inline, while waiting for suggestions from more expert guys
and of course look at
http://www.slideshare.net/geosolutions/geoserver-on-steroids
by Andrea Aime and Simone Giannecchini
2013/2/20 dkotian95 <dkotian95@anonymised.com>:
U.S.
Question:
shapefile is usually faster, but if you have to split layers probably
Oracle or PostGIS is a better choice.
By the way spatial option requires Oracle Enterprise edition , that is
big bucks to put on the project budget. Consider using Locator, you
don't need spatial for storing data in SDO_GEOMETRY, or better have a
look at PostGIS.
Using shapefile or Oracle I would use GeoWebCache anyway. The only
reason against caching your data is if they are updated very
frequently.
Kindly suggest.
best Regards
dk
Kind Regards,
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
On Wed, Feb 20, 2013 at 5:08 PM, dkotian95 <dkotian95@anonymised.com> wrote:
U.S.
Short addendum to what Stefano already said.
Generally speaking, shapefile performance is very good in GeoServer, they are
far superior to spatial databases when you are trying to display all of the data
in a single small map, however they fall short if you ever need a non spatial
index to speed up searches on non spatial attributes, and not an option if
you are trying to do WFS-T editing.
The indexing thing might become important if you do CQL filters to display only
a portion of the data, or if you have styles that display only a subset of the data
based on some logic (e.g., displaying only highways in a road map, when zoomed
out).
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Andrea/Stefano.
Is there any performance benchmark between shape and oracle with geoserver. Can I use geoserver directly with shapefile for data of this size without webcache with around 25-30 concurrent users.
Thanks and Regards
Deepak
On Thu, Feb 21, 2013 at 2:48 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
U.S.
out).
Ing. Andrea Aime
@geowolf
Technical Lead
