[Geoserver-users] Performance issue with extreme zoom
Hello everyone,
I have some issues with my geoserver instance. I am working with geoserver 2.8.2, with the GRIB and INSPIRE plugins. The GRIB files I serve are not that big (30 files, ~2Mo each).
When an user starts requesting a map with an extreme zoom, Geoserver is not able to render the map : A process runs during more than one hour, without any result. These requests accumulate and the whole server can not satisfy any request anymore.
Here is a example of a box that causes this problem :
BBOX=52.373962891801554,3.2711379635382203,52.37471041281445,3.2718854845511154
I kept the maximum rendering time to 120 seconds in WMS options, but it does not seem to have an impact.
Does someone have an idea to fix this problem ?
The amount of data I have is quite small at the moment, and the fact that one user is able to absorb the whole server load with a few requests is worrisome.
Thank You.
Joffrey
Hi Joffrey,
a couple of questions to get some more background info on that.
Which OS?
Are the input GRIB file in WGS84 or are them into some different CRS and being reprojected as part of the request?
What is the native resolution of your samples and what is the resolution you are requesting to make the request never end?
Please, let us know.
Daniele
On Tue, Jun 14, 2016 at 3:17 PM, Joffrey Schmitz <jschmitz@anonymised.com> wrote:
Hello everyone,
Thank You.
Joffrey
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
Additional note:
in the past months, we have fixed an issue with a processing operation which resulted in heavy loading when dealing with reprojection and big oversampling.
If that’s your case, you may consider trying a nightly 2.8.x or wait for a 2.8.4 which will contain that fix.
The problem was: https://osgeo-org.atlassian.net/browse/GEOT-5391
Daniele
On Tue, Jun 14, 2016 at 4:09 PM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hi Joffrey,
Which OS?
Daniele
Hello everyone,
Thank You.
Joffrey
Hi Daniele,
Here is the informations you requested :
  • Our instance of Geoserver runs on CentOS release 6.5 (Final)
  • The native SRS is this one :
    GEOGCS[“WGS 84”,
    DATUM[“World Geodetic System 1984”,
    SPHEROID[“WGS 84”, 6378137.0, 298.257223563, AUTHORITY[“EPSG”,“7030”]],
    AUTHORITY[“EPSG”,“6326”]],
    PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
    UNIT[“degree”, 0.017453292519943295],
    AXIS[“Geodetic longitude”, EAST],
    AXIS[“Geodetic latitude”, NORTH],
    AUTHORITY[“EPSG”,“4326”]]
    and the CRS requested by the user is the same : CRS=EPSG:4326
The original GRIB file has the following properties :
Ni = 177;
Nj = 177;
latitudeOfFirstGridPointInDegrees = 47.397;
longitudeOfFirstGridPointInDegrees = -0.115;
latitudeOfLastGridPointInDegrees = 53.623;
longitudeOfLastGridPointInDegrees = 9.222;
jDirectionIncrementInDegrees = 0.035;
iDirectionIncrementInDegrees = 0.053;
The following BBOX makes the request never ends :
BBOX=47.97552463980568,2.941473886397377,47.97552466575646,2.9414739123481577
That kind of boxes is extreme… It is a big zoom on one cell of the raster data.
Thank you for your answer.
Joffrey
De: “Daniele Romagnoli” daniele.romagnoli@anonymised.com
À: “Joffrey Schmitz” jschmitz@anonymised.com
Envoyé: Mardi 14 Juin 2016 16:32:42
Objet: Re: [Geoserver-users] Performance issue with extreme zoom
Additional note:
Daniele
Hi Joffrey,
Which OS?
Daniele
Hello everyone,
Thank You.
Joffrey
Hi Daniele,
I read the log more carrefully and there was indeed a reprojection with the request.
I switched to a nightly build Geoserver 2.8.X, and that type of request seems to be correctly handled now.
Thank you for your help !
Joffrey
De: “Daniele Romagnoli” <daniele.romagnoli@anonymised.com…1107…>
Additional note:
Daniele
Hi Joffrey,
Which OS?
Daniele
On Tue, Jun 14, 2016 at 3:17 PM, Joffrey Schmitz <jschmitz@anonymised.com80…> wrote:
Hello everyone,
Thank You.
Joffrey
