[Geoserver-users] Performance of ECQL-Filter with up to 5000 IDs
I have a WMS request including a rather long ECQL-Filter that matches on feature IDs (as described in http://docs.geoserver.org/latest/en/user/tutorials/cql/cql_tutorial.html#id-and-list-comparisons).
The filter is like this:
IN (‘mylayer.101453’, …up to 5000 IDs here… ,‘mylayer.102486’)
If there are only a few hundred IDs the response is at about 500ms, but with up to 5000 it becomes 15-30 seconds. Any ideas on how to optimize? 2, 3 seconds would sound acceptable but half a minute is a bit too much.
GeoServer Version is 2.7
Best,
Jens
On Fri, Jul 31, 2015 at 4:02 PM, Nachtigall, Jens (init) <
Jens.Nachtigall@anonymised.com> wrote:
IN ('mylayer.101453', ...up to 5000 IDs here... ,'mylayer.102486')
What is the datastore backing the request?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
It’s Oracle.
On Fri, Jul 31, 2015 at 4:02 PM, Nachtigall, Jens (init) <Jens.Nachtigall@…5799…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
