[Geoserver-users] Performance of ECQL-Filter with up to 5000 IDs
so do you think the database connection is the bottleneck? I would need some pointer on where to optimize or at least how to find the bottleneck (or how can I do some profiling/benchmarking/debugging to find the bottleneck?)
Or is it just normal that an ECQL-Filter on many IDs is very slow?
Best,
Jens
Von: Nachtigall, Jens (init) [mailto:Jens.Nachtigall@…5799…]
Gesendet: Freitag, 31. Juli 2015 16:29
An: geoserver-users@lists.sourceforge.net
Betreff: Re: [Geoserver-users] Performance of ECQL-Filter with up to 5000 IDs
It’s Oracle.
Von: andrea.aime@…84… [mailto:andrea.aime@…84…] Im Auftrag von Andrea Aime
Gesendet: Freitag, 31. Juli 2015 16:11
An: Nachtigall, Jens (init)
On Fri, Jul 31, 2015 at 4:02 PM, Nachtigall, Jens (init) <Jens.Nachtigall@…5799…> wrote:
I have a WMS request including a rather long ECQL-Filter that matches on feature IDs (as described in http://docs.geoserver.org/latest/en/user/tutorials/cql/cql_tutorial.html#id-and-list-comparisons).
The filter is like this:
IN (‘mylayer.101453’, …up to 5000 IDs here… ,‘mylayer.102486’)
If there are only a few hundred IDs the response is at about 500ms, but with up to 5000 it becomes 15-30 seconds. Any ideas on how to optimize? 2, 3 seconds would sound acceptable but half a minute is a bit too much.
What is the datastore backing the request?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Jens,
without knowing anything about your system, it's probably a question of optimizing the SQL which results from the CQL. Consider things like indexing - is the database utilizing any index? Also, a query which fetches specific IDs is probably not the optimum way to fetch thousands of features. Consider whether the query can be expressed better, or possibly whether the data needs to be remodelled.
Just a few loose ideas :slight_smile:
/julian
________________________________________
Fra: Nachtigall, Jens (init) [Jens.Nachtigall@anonymised.com]
Sendt: 3. august 2015 09:59
Til: geoserver-users@lists.sourceforge.net
Emne: Re: [Geoserver-users] Performance of ECQL-Filter with up to 5000 IDs
Best,
Jens
Von: Nachtigall, Jens (init) [mailto:Jens.Nachtigall@anonymised.com]
It’s Oracle.
Von: andrea.aime@anonymised.com<mailto:andrea.aime@anonymised.com> [mailto:andrea.aime@…84…] Im Auftrag von Andrea Aime
Cc: geoserver-users@lists.sourceforge.net<mailto:geoserver-users@anonymised.comceforge.net>
On Fri, Jul 31, 2015 at 4:02 PM, Nachtigall, Jens (init) <Jens.Nachtigall@anonymised.com..5799...<mailto:Jens.Nachtigall@anonymised.com>> wrote:
IN ('mylayer.101453', ...up to 5000 IDs here... ,'mylayer.102486')
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Mon, Aug 3, 2015 at 9:59 AM, Nachtigall, Jens (init) <
Jens.Nachtigall@anonymised.com> wrote:
bottleneck?)
I think that a SQL query with 5000 ids is probably slow. Check your SQL
query setting the
logging level to "geotools developer logging".
I know we translate it to a long series of "pk = firstValue or pk =
secondValue or ...",
a "pk in (v1, v2, ...)" would be more compact, but any database worth its
salt
should realize the two are equivalent at the query planner level (but with
Oracle
one never knows)
Ing. Andrea Aime
@geowolf
Technical Lead
