[Geoserver-users] PerpendicularOffset not working
Hello,
I'm trying to apply a PerpendicularOffset to a stroke, but it is not being
applied.
Here is my code:
        <se:Rule>
          <se:Name>test</se:Name>
          <ogc:Filter>
            <ogc:PropertyIsEqualTo>
              <ogc:Function name="dimension">
                <ogc:PropertyName>geom</ogc:PropertyName>
              </ogc:Function>
              <ogc:Literal>1</ogc:Literal>
            </ogc:PropertyIsEqualTo>
          </ogc:Filter>
          <se:LineSymbolizer>
            <se:Stroke>
              <se:SvgParameter name="stroke">#000000</se:SvgParameter>
              <se:SvgParameter name="stroke-width">1</se:SvgParameter>
              <se:SvgParameter name="stroke-dasharray">38 0</se:SvgParameter>
              <se:SvgParameter name="stroke-dashoffset">0</se:SvgParameter>
            </se:Stroke>
          </se:LineSymbolizer>
          <se:LineSymbolizer>
            <se:Stroke>
              <se:SvgParameter name="stroke-dasharray">2 36</se:SvgParameter>
            </se:Stroke>
                        <se:PerpendicularOffset>10</se:PerpendicularOffset>
          <se:LineSymbolizer>
            <se:Stroke>
              <se:GraphicStroke>
                <se:Graphic>
                  <se:ExternalGraphic>
                    <se:OnlineResource xlink:type="simple" xlink:href="emrail01.svg"/>
                    <se:Format>image/svg+xml</se:Format>
                  </se:ExternalGraphic>
                  <se:Size>12</se:Size>
                  <se:Displacement>
                    <se:DisplacementX>0</se:DisplacementX>
                    <se:DisplacementY>-1</se:DisplacementY>
                  </se:Displacement>
                </se:Graphic>
              </se:GraphicStroke>
              <se:SvgParameter name="stroke-dashoffset">10</se:SvgParameter>
            </se:Stroke>
          <se:LineSymbolizer>
            <se:Stroke>
              <se:GraphicStroke>
                <se:Graphic>
                                    <se:Rotation>180</se:Rotation>
                  <se:Displacement>
                  </se:Displacement>
                </se:Graphic>
              </se:GraphicStroke>
            </se:Stroke>
          <se:LineSymbolizer>
            <se:Stroke>
              <se:GraphicStroke>
                <se:Graphic>
                  <se:Displacement>
                  </se:Displacement>
                </se:Graphic>
              </se:GraphicStroke>
              <se:SvgParameter name="stroke-dashoffset">29</se:SvgParameter>
            </se:Stroke>
          <se:LineSymbolizer>
            <se:Stroke>
              <se:GraphicStroke>
                <se:Graphic>
                  <se:Displacement>
                  </se:Displacement>
                </se:Graphic>
              </se:GraphicStroke>
            </se:Stroke>
        </se:Rule>
This is the result I have:
<http://osgeo-org.1560.x6.nabble.com/file/n5265216/xfELJ2K.png&gt;
This is what I want:
<http://osgeo-org.1560.x6.nabble.com/file/n5265216/xXZ3Qqg.png&gt;
So as you can see, I would like to have this little dash on the top and I
try to add it with this line of code and perpendicularoffset:
          <se:LineSymbolizer>
            <se:Stroke>
            </se:Stroke>
But it's just not working.
This piece of code has no effect.
thank you
View this message in context: http://osgeo-org.1560.x6.nabble.com/PerpendicularOffset-not-working-tp5265216.html
Hi Geoffrey,
I did not check the SLD yet, but wondering which version of GeoServer you are using, you’ll
need at least version 2.9.x in order to get support for perpendicular offset, older versions
just don’t know how to compute it.
There is now out 2.9-RC2 (http://blog.geoserver.org/2016/05/03/geoserver-2-9-rc1-released/ ) but
the announcement is not citing the new features, which are instead listed in the 2.9-beta announcement:
http://blog.geoserver.org/2016/03/01/geoserver-2-9-beta-released/
On Sun, May 8, 2016 at 4:00 PM, Geoffrey <balmeg@…84…> wrote:
Hello,
I’m trying to apply a PerpendicularOffset to a stroke, but it is not being
applied.
Here is my code:
se:Rule
se:Nametest</se:Name>
ogc:Filter
<ogc:Function name=“dimension”>
ogc:PropertyNamegeom</ogc:PropertyName>
</ogc:Function>
ogc:Literal1</ogc:Literal>
</ogc:Filter>
se:LineSymbolizer
se:Stroke
<se:SvgParameter name=“stroke”>#000000</se:SvgParameter>
<se:SvgParameter name=“stroke-width”>1</se:SvgParameter>
<se:SvgParameter name=“stroke-dasharray”>38 0</se:SvgParameter>
<se:SvgParameter name=“stroke-dashoffset”>0</se:SvgParameter>
</se:Stroke>
se:LineSymbolizer
se:Stroke
<se:SvgParameter name=“stroke-dasharray”>2 36</se:SvgParameter>
</se:Stroke>
se:PerpendicularOffset10</se:PerpendicularOffset>
se:LineSymbolizer
se:Stroke
se:GraphicStroke
se:Graphic
se:ExternalGraphic
<se:OnlineResource xlink:type=“simple” xlink:href=“emrail01.svg”/>
se:Formatimage/svg+xml</se:Format>
se:Size12</se:Size>
se:Displacement
se:DisplacementX0</se:DisplacementX>
se:DisplacementY-1</se:DisplacementY>
</se:Displacement>
</se:Graphic>
</se:GraphicStroke>
<se:SvgParameter name=“stroke-dashoffset”>10</se:SvgParameter>
</se:Stroke>
se:LineSymbolizer
se:Stroke
se:GraphicStroke
se:Graphic
se:ExternalGraphic
se:Size12</se:Size>
se:Rotation180</se:Rotation>
se:Displacement
</se:Displacement>
</se:Graphic>
</se:GraphicStroke>
</se:Stroke>
se:LineSymbolizer
se:Stroke
se:GraphicStroke
se:Graphic
se:ExternalGraphic
se:Size12</se:Size>
se:Displacement
</se:Displacement>
</se:Graphic>
</se:GraphicStroke>
<se:SvgParameter name=“stroke-dashoffset”>29</se:SvgParameter>
</se:Stroke>
se:LineSymbolizer
se:Stroke
se:GraphicStroke
se:Graphic
se:ExternalGraphic
se:Size12</se:Size>
se:Displacement
</se:Displacement>
</se:Graphic>
</se:GraphicStroke>
</se:Stroke>
</se:Rule>
<http://osgeo-org.1560.x6.nabble.com/file/n5265216/xfELJ2K.png>
<http://osgeo-org.1560.x6.nabble.com/file/n5265216/xXZ3Qqg.png>
se:LineSymbolizer
se:Stroke
</se:Stroke>
But it’s just not working.
thank you
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Thanks Andrea,
The problem is that I've Geoserver 2.8 installed because I installed OpenGeo
Suite 4.8 on my laptop.
How can I install Geoserver 2.9 without breaking all my OpenGeo Suite setup
? (I have also postGIS installed etc...)
thank you
View this message in context: http://osgeo-org.1560.x6.nabble.com/PerpendicularOffset-not-working-tp5265216p5265233.html
You would need to ask boundless (assuming you have a support contract), we can only advise on GeoServer issues.
Ian
On 8 May 2016 18:26, “Geoffrey” <balmeg@anonymised.com> wrote:
Thanks Andrea,
The problem is that I’ve Geoserver 2.8 installed because I installed OpenGeo
? (I have also postGIS installed etc…)
thank you
I don’t use the Opengeo Suite so I don’t have any idea, sorry… Maybe someone from Boundless can chime in and give you directions…
Il 08 mag 2016 8:33 PM, “Geoffrey” <balmeg@anonymised.com> ha scritto:
Thanks Andrea,
thank you
