Hello:
Has anyone successfully used the PGraster plugin in Geoserver v 2.7 or 2.8 for a Linux box.
-Vijay Ramalingam
Hello:
-Vijay Ramalingam
We successfully implemented it.
What questions do you have?
On Mon, Aug 3, 2015 at 5:05 PM, Vijay Ramalingam <vramalingam@anonymised.com…> wrote:
Hello:
2.8 for a Linux box.-Vijay Ramalingam
Geoserver-users mailing list
David Haynes, Ph.D.
Research Associate Terra Populus
Minnesota Population Center
www.terrapop.org
Hi David,
Is there a .jar file available for this plugin? If not, how do I create one?
-Vijay
What questions do you have?On Mon, Aug 3, 2015 at 5:05 PM, Vijay Ramalingam <vramalingam@anonymised.com <mailto:vramalingam@anonymised.com>> wrote:
Hello:
<mailto:Geoserver-users@lists.sourceforge.net>
https://lists.sourceforge.net/lists/listinfo/geoserver-users--
David Haynes, Ph.D.
www.terrapop.org <http://www.terrapop.org>
There is a jar file you can download and add the JDBC image mosaic extensions.
http://geoserver.org/release/stable/
On Tue, Aug 4, 2015 at 5:25 PM, Vijay Ramalingam <vramalingam@anonymised.com> wrote:
Hi David,
On Mon, Aug 3, 2015 at 5:05 PM, Vijay Ramalingam <vramalingam@anonymised.com> wrote:
Hello:
David Haynes, Ph.D.
www.terrapop.org
David Haynes, Ph.D.
www.terrapop.org
Thanks. I found it here: http://repo.boundlessgeo.com/main/org/geoserver/community/gs-pgraster/2.7.1.1/
http://geoserver.org/release/stable/On Tue, Aug 4, 2015 at 5:25 PM, Vijay Ramalingam <vramalingam@anonymised.com <mailto:vramalingam@anonymised.com>> wrote:
Hi David,
create one?Thanks,
<mailto:vramalingam@anonymised.com>> wrote:Hello:
v 2.7 or
https://lists.sourceforge.net/lists/listinfo/geoserver-users-- David Haynes, Ph.D.
www.terrapop.org <http://www.terrapop.org>------------------------------------------------------------------------------
David Haynes, Ph.D.
