hi, i have an urgent question about php and geoserver!
how does the geoserver interpret php and where do i have to save the php
files?
View this message in context: http://www.nabble.com/php-and-geoserver-tp21624353p21624353.html
files?
GeoServer does not interpret PHP. If you would like to serve PHP
scripts from the same port as a GeoServer instance you will need to use
an HTTP reverse proxy and PHP-enabled web server; Apache's http serves
as both. http://httpd.apache.org/
Hope this helps.
David Winslow
OpenGeo - http://opengeo.org/
