[Geoserver-users] Pink Tiles- Raster
Dear All,
I have used Imagemosaic to load the raster into geoserver (approx 140 TIFF's
- 6.5 GB) . While displaying into our portal some tiles display pink in
color (ref the attached screenshot) .I have use pageinfo option in firefox
to know the exact reason of the issue I have got the following WMS error.
*<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
ServiceExceptionReport SYSTEM
&quot;http://54.187.234.74:8080/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd&quot;&gt;
<ServiceExceptionReport version="1.1.1" > <ServiceException>
      Error rendering coverage on the fast path
org.geotools.data.DataSourceException: Unable to create this mosaic
null
</ServiceException></ServiceExceptionReport>*
Kindly let me what may be issue ASAP.
Thanks in advance,
K.Jayakumar
<http://osgeo-org.1560.x6.nabble.com/file/n5162869/pink.jpg&gt;
View this message in context: http://osgeo-org.1560.x6.nabble.com/Pink-Tiles-Raster-tp5162869.html
Dear All,
May I know the issue behind the pink tiles loading and what are the steps
need to take.
K.Jayakumar
View this message in context: http://osgeo-org.1560.x6.nabble.com/Pink-Tiles-Raster-tp5162869p5163396.html
can you please share the full stacktrace of the error you get? You should be able to find it in the geoserver.log file, in the logs subfolder of the data dir.
Mauro
2014-09-19 12:39 GMT+02:00 jkumar <jayakumar@anonymised.com>:
Dear All,
I have used Imagemosaic to load the raster into geoserver (approx 140 TIFF’s
  • 6.5 GB) . While displaying into our portal some tiles display pink in
null
Thanks in advance,
K.Jayakumar
<http://osgeo-org.1560.x6.nabble.com/file/n5162869/pink.jpg>
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Hi Mauro,
Thanks for your reply and please find the log file available in the link
https://www.dropbox.com/s/vsgbo8jpo8w29q0/geoserver.log?dl=0
You can find the error in line number 95088.
Regards.
K.Jayakumar
View this message in context: http://osgeo-org.1560.x6.nabble.com/Pink-Tiles-Raster-tp5162869p5163742.html
your problem could be a bug of the 2.4.0 release you are using. Have you tried upgrading to a newer version?
Mauro Bartolomeoli
2014-09-23 7:29 GMT+02:00 jkumar <jayakumar@anonymised.com>:
Dear All,
need to take.
K.Jayakumar
Hi Mauro,
Thanks for the reply. I will try it in upgrade version and let you know.
K.Jayakumar
View this message in context: http://osgeo-org.1560.x6.nabble.com/Pink-Tiles-Raster-tp5162869p5164640.html
in order to get an idea about the problem you would need to change the
logging level to something geotools developer and then send the log
again.
That said, if you are showing the mosaic at all scales, once you zoom
out a bit more having to load 140 files may lead to response failing
as you are definitely opening too many files for a single request.
Check these slides for some additional information:
http://goo.gl/74XUPq
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Mon, Sep 29, 2014 at 6:04 AM, jkumar <jayakumar@anonymised.com> wrote:
Hi Mauro,
K.Jayakumar
Slashdot TV. Videos for Nerds. Stuff that Matters.
http://pubads.g.doubleclick.net/gampad/clk?id=160591471&iu=/4140/ostg.clktrk
