I am loading my maps through GeoServer using WMS in openlayers.
Everything is going well. However sometimes when I load the maps using wifi
network i get pink tiles generated. Can anyone explain me why?
Hi
Pink tiles means that OpenLayers is unable to get the tiles it wants. This could be either because the GeoServer is broken, the layers are wrongly set up on the server, or (probably in this case as it only happens on wifi), the internet connection is flaky.
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
