[Geoserver-users] Please test the GeoServer 2.7.5 release artifacts
New artifacts are available at http://ares.boundlessgeo.com/geoserver/release/2.7.5/ please test them - especially if you use an exotic system the dev’s don’t like windows?
Ian
Ian Turton
especially if you use an exotic system the dev's don't like windows?
I did a quick smoke test of the war on tomcat 7 (on my Linux laptop). I see
    Version
    2.7.5
    Git Revision
    26f0e9f908fcc279652e0c2622db1028469be16e
    Build Date
    19-Dec-2015 11:32
    GeoTools Version
    13.5 (rev 2046ab12ba9f686048a384ed488eaf5fa457355b)
    GeoWebCache Version
    1.7.3 (rev
a09f77d3b14d4bbcee3feb407fd2d8ea2cf62d64/a09f77d3b14d4bbcee3feb407fd2d8ea2cf62d64)
Checked layer preview looked OK for each of the data sets. I checked
openlayers for each, and a couple of other formats along the way.
I added the CSW and WCS-EO extensions and verified that the server looks OK and
that CSW GetCapabilities works.
Checked GetCapabilities works for WCS 2.0.1, TMS, WMS-C, WMTS.
Looks good.
Brad
Running 2.7.5 on Tomcat 7.0.59 on Windows Server 2012.
Java 7.0.65 server JVM
Native JAI ImageIO
Build Information
    Version
    2.7.5
    Git Revision
    Build Date
    19-Dec-2015 11:32
    GeoTools Version
    GeoWebCache Version
    1.7.3 (rev a09f77d3b14d4bbcee3feb407fd2d8ea2cf62d64/a09f77d3b14d4bbcee3feb407fd2d8ea2cf62d64)
Layer preview works with GeoTIFF, ImageMosaic, PostGIS layers
Integrated GWC works too
GetCapabilities for WMS, WFS and WMS-C all work as expected.
Installed the following plugins
* control flow
* Inspire
* Libjpeg turbo
* jdbc config (caused an error: Dec 21, 2015 12:29:27 PM org.apache.catalina.loader.WebappClassLoader clearReferencesJdbc
SEVERE: The web application [/geoserver] registered the JDBC driver [org.hsqldb.jdbc.JDBCDriver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.) I deleted the plugin and the Geoserver started.
* jms cluster
HTH
Ross
-----Original Message-----
Sent: 20 December 2015 00:12
Subject: Re: [Geoserver-users] Please test the GeoServer 2.7.5 release artifacts
- especially if you use an exotic system the dev's don't like windows?
    Version
    2.7.5
    Git Revision
    Build Date
    19-Dec-2015 11:32
    GeoTools Version
    GeoWebCache Version
    1.7.3 (rev
Looks good.
Brad
Geoserver-users mailing list
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
Looks good to me, Ian.
Using openjdk-8-jdk 8u72-b05-5 amd64 on debian/unstable, running the bin-zip embedded Jetty, I tested several layer previews and demo requests and nothing seemed out of place.
Kind regards,
Ben.
Ian
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
