[Geoserver-users] Pluggable Change Notification
I'm wondering if there is any existing capability to generate notifications when something of interest in GeoServer changes.
For example, if I register a new layer, would there be a way to generate an alert or other message which would let downstream consumers know about the new info available?
Thanks in advance,
Jim
There is some facility in the different OGC specs for change notification - the easiest is polling a WMS GetCapabilities and checking if the update sequence.
Still you may have a good idea for the a community module or the REST API. I guess something like an RSS feed for GetCapabilities changes would be appropriate.
On 21 January 2015 at 11:33, Jim Hughes <jnh5y@anonymised.com> wrote:
I’m wondering if there is any existing capability to generate
Thanks in advance,
Jim
New Year. New Location. New Benefits. New Data Center in Ashburn, VA.
GigeNET is offering a free month of service with a new server in Ashburn.
Choose from 2 high performing configs, both with 100TB of bandwidth.
Higher redundancy.Lower latency.Increased capacity.Completely compliant.
http://p.sf.net/sfu/gigenet
Geoserver-users mailing list
Jody Garnett
On Wed, Jan 21, 2015 at 8:33 PM, Jim Hughes <jnh5y@anonymised.com> wrote:
Yes, you just have to drop into GeoServer a new jar with a CatalogListener
implementation of your own, and its registration in applicationContext.xml.
If you are interested in data changes via wfs-t we also have transaction
listener
extension points.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea, Jody,
Thanks for the responses. I think the CatalogListener is exactly what I’m looking for.
Jim
If you are interested in data changes via wfs-t we also have transaction listener
extension points.
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Jan 22, 2015 at 9:25 PM, Jim Hughes <jnh5y@anonymised.com> wrote:
Hi Andrea, Jody,
Thanks for the responses. I think the CatalogListener is exactly what I'm
looking for.
By the way, you shoud have a look at the two catalog clustering modules in
community land,
they are both good examples of catalog listeners to propagate changes in
the catalog in one
cluster node to other nodes in the same cluster (and as such, pretty
complete examples
of what a listener is about).
Ing. Andrea Aime
@geowolf
Technical Lead
