[Geoserver-users] Plugins loading and debug errors
Hi List,
I’ve just upgraded from 2.2.2 to 2.2.3.
With 2.2.2, I installed the JP2K plugin, but decided not to with 2.2.3 because I’ve gone down a different route.
However, now whenever I start 2.2.3, I get a wall of debug errors in the log. Shortened they’re:
2013-01-04 12:41:19,319 DEBUG [org.geotools.gce.imagemosaic] - Unable to load kakadu JPEG2000 reader spi
java.lang.ClassNotFoundException: it.geosolutions.imageio.plugins.jp2k.JP2KKakaduImageReaderSpi
at java.net.URLClassLoader$1.run(Unknown Source)
2013-01-04 12:41:19,397 DEBUG [org.geotools.gce.imagemosaic] - Unable to load GDAL JP2 ECW Reader SPI
java.lang.ClassNotFoundException: it.geosolutions.imageio.plugins.jp2ecw.JP2GDALEcwImageReaderSpi
2013-01-04 12:41:19,475 DEBUG [org.geotools.gce.imagemosaic] - Unable to load GDAL JP2 MrSID Reader SPI
java.lang.ClassNotFoundException: it.geosolutions.imageio.plugins.jp2mrsid.JP2GDALMrSidImageReaderSpi
2013-01-04 12:41:19,569 DEBUG [org.geotools.gce.imagemosaic] - Unable to load GDAL JP2 Kakadu Reader SPI
java.lang.ClassNotFoundException: it.geosolutions.imageio.plugins.jp2kakadu.JP2GDALKakaduImageReaderSpi
None of the layers I have are using these but GeoServer is searching for them anyway. Is there a way to stop this? I can’t find any references to them in the Geoserver_data directory.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Ciao Jonathan,
these are not errors per se. You are working with a logging level that
shows every single info in geoserver hence you see these messages.
Just to clarify, geoserver is looking for optional plugins and
reporting that it fails to load them, that is they won't be available
from that point onwards.
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Fri, Jan 4, 2013 at 2:33 PM, Jonathan Moules
<jonathanmoules@anonymised.com> wrote:
Hi List,
I've just upgraded from 2.2.2 to 2.2.3.
because I've gone down a different route.
log. Shortened they're:
them anyway. Is there a way to stop this? I can't find any references to
Jonathan
Master HTML5, CSS3, ASP.NET, MVC, AJAX, Knockout.js, Web API and
much more. Get web development skills now with LearnDevNow -
350+ hours of step-by-step video tutorials by Microsoft MVPs and experts.
SALE $99.99 this month only -- learn more at:
http://p.sf.net/sfu/learnmore_122812
Geoserver-users mailing list
