tnx for the suggestions. I've checked the Mapfish Print v.3.6.0
classes, and I see that they have now also included all jt-* classes.
I've just created multiple Tomcat Instances and separated GS and MapFish apps.
Hi Ivan,
I guess you might have some classpath issue, the
it.geosolutions.jaiext.colorindexer.CachingColorIndexer
is an instance of it.geosolutions.jaiext.colorindexer.ColorIndexer available
in the same package inside
jai-ext jt-colorindexer jar.
May it be that you have two of those jars around with different versions,
like twice in the war, or in the war and in the
tomcat libs, or for any obscure reason, in the war and in the jre lib/ext
directory?
The ColorIndexer interface is jai-ext own, has no relationship with normal
JAI, so I don't know
off the top of my head how having native versions of JAI would cause the
above issue.
On Wed, Aug 3, 2016 at 11:47 AM, Ivan Grcic <igrcic@anonymised.com> wrote:
Hi everybody,
recently we installed native Java JAI+ImageIO libs (new MapFish
version requires it), and since then we are getting Exceptions for
PNG8 Image format (PNG works just ok)
<ServiceException>
java.lang.IllegalArgumentException: ColorIndexer - Parameter value`s
class (it.geosolutions.jaiext.colorindexer.CachingColorIndexer) is not
an instance of the parameter class
(it.geosolutions.jaiext.colorindexer.ColorIndexer) for parameter
"Indexer". ColorIndexer - Parameter value`s class
(it.geosolutions.jaiext.colorindexer.CachingColorIndexer) is not an
"Indexer".
</ServiceException>
Is Geoserver still expected to work normal with Native JAI/ImageIO
libs, or one has to make a switch to Community JAI-Ext Version in
order everything to work fine?
We are currently still using Geoserver v2.8, as few important issues
still prevents us to upgrade to v2.9.
Thank you!
Kind regards,
Ivan
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
