is it possible to use a db, say Oracle without its spatial extension as a Data source in GeoServer, where the Point geometry is simply stored in two separate columns?
The columns are simply “lon” and “lat” containing floats.
That is, can I simply map these lon/lat columns in GeoServer and let GeoServer know that these are my geometry?
Did you need GeoServer for some specific purpose for said X|Y coordinates -like creating a WMS layer? If there is no ‘good’ reason to use GeoServer then said data can simply be accessed via your webcore(read Leaflet or OpenLayer and node.js, as an example).
Eric
On Sep 11, 2014, at 7:10 AM, Nachtigall, Jens (init) <Jens.Nachtigall@anonymised.com99...> wrote:
is it possible to use a db, say Oracle *without* its spatial extension as a Data source in GeoServer, where the Point geometry is simply stored in two separate columns?
Best,
Jens
Yes, I need it for OGC services, that is WFS and WMS.
Von: Eric Jarvies [mailto:7@anonymised.com] Gesendet: Donnerstag, 11. September 2014 16:41 An: Nachtigall, Jens (init) Cc:geoserver-users@lists.sourceforge.net Betreff: Re: [Geoserver-users] Point Geometry in lon/lat columns of non-spatial db
Jens,
Or we could just implement a GUI for gt-transform, it is supposed to have
management for that
problem too (turn two columns into a single point inside geoserver)
GeoServer Professional Services from the experts! Visit http://goo.gl/NWWaa2 for more information.
Ing. Andrea Aime @geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Mon, Sep 15, 2014 at 1:42 PM, Andrea Aime <andrea.aime@anonymised.com>
management for that
Good thinking, going for the general purpose solution.
Was thinking of calling it "Java Views" or something (in order to be
similar to SQL views). "Transform view", "Local View" or "View" is probably
just better.
Jody
