[Geoserver-users] Polygon pattern made of multiples SVGs
Hello,
I would like to have a polygon filled with a pattern made from multiple
SVGs, or one SVGs but with different placements.
For example, I tried this:
<se:PolygonSymbolizer>
  <se:Fill>
    <se:GraphicFill>
      <se:Graphic>
        <se:ExternalGraphic>
          <se:OnlineResource xlink:type="simple" xlink:href="pattern.svg" />
          <se:Format>image/svg+xml</se:Format>
        </se:ExternalGraphic>
        <se:Size>12</se:Size>
        <se:Displacement>
          <se:DisplacementX>18</se:DisplacementX>
          <se:DisplacementY>0</se:DisplacementY>
        </se:Displacement>
      </se:Graphic>
    </se:GraphicFill>
  </se:Fill>
</se:PolygonSymbolizer>
  <se:Fill>
    <se:GraphicFill>
      <se:Graphic>
        <se:Displacement>
          <se:DisplacementX>9</se:DisplacementX>
          <se:DisplacementY>18</se:DisplacementY>
        </se:Displacement>
      </se:Graphic>
    </se:GraphicFill>
  </se:Fill>
The goal was to have a pattern made from the image pattern.svg at 2
different places (that's why I try to use displacement)
Pattern.svg would be like this:
<http://osgeo-org.1560.x6.nabble.com/file/n5257478/patternimage.jpg&gt;
And the final pattern would render like so:
<http://osgeo-org.1560.x6.nabble.com/file/n5257478/pattern.jpg&gt;
Unfortunately, this is not working.
Any idea how to do this ?
Thank you
View this message in context: http://osgeo-org.1560.x6.nabble.com/Polygon-pattern-made-of-multiples-SVGs-tp5257478.html
Hi Geoffrey,
try to play with the margin vendor option instead:
http://docs.geoserver.org/latest/en/user/styling/sld-extensions/margins.html
On Sun, Mar 20, 2016 at 1:52 PM, Geoffrey <balmeg@anonymised.com> wrote:
Hello,
se:Fill
se:GraphicFill
se:Graphic
se:ExternalGraphic
<se:OnlineResource xlink:type=“simple” xlink:href=“pattern.svg” />
se:Formatimage/svg+xml</se:Format>
se:Size12</se:Size>
se:Displacement
se:DisplacementX18</se:DisplacementX>
se:DisplacementY0</se:DisplacementY>
</se:Displacement>
</se:Graphic>
</se:GraphicFill>
</se:Fill>
se:Fill
se:GraphicFill
se:Graphic
se:ExternalGraphic
se:Size12</se:Size>
se:Displacement
se:DisplacementX9</se:DisplacementX>
se:DisplacementY18</se:DisplacementY>
</se:Displacement>
</se:Graphic>
</se:GraphicFill>
</se:Fill>
different places (that’s why I try to use displacement)
<http://osgeo-org.1560.x6.nabble.com/file/n5257478/patternimage.jpg>
<http://osgeo-org.1560.x6.nabble.com/file/n5257478/pattern.jpg>
Thank you
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785231&iu=/4140
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
I tried to play with the margin plugin, and here is what I managed to
achieve:
<http://osgeo-org.1560.x6.nabble.com/file/n5257800/polygon.jpg&gt;
Unfortunately, as you can see this is not as the render I would like to
have:
<http://osgeo-org.1560.x6.nabble.com/file/n5257800/pattern.jpg&gt;
Here is the code I used:
            <se:Fill>
              <se:GraphicFill>
                <se:Graphic>
                </se:Graphic>
              </se:GraphicFill>
            </se:Fill>
            <VendorOption name="graphic-margin">18 9 18 9</VendorOption>
            <se:Stroke>
              <se:SvgParameter name="stroke">#EA5471</se:SvgParameter>
              <se:SvgParameter name="stroke-width">1</se:SvgParameter>
            </se:Stroke>
            <se:Fill>
              <se:GraphicFill>
                <se:Graphic>
                </se:Graphic>
              </se:GraphicFill>
            </se:Fill>
            <VendorOption name="graphic-margin">0 0 36 18</VendorOption>
            <se:Stroke>
            </se:Stroke>
Could the problem be because I'm not taking account of the size of the svg ?
If yes, how should I do ?
The svg I'm using is 10*10
Thank you for your help !
View this message in context: http://osgeo-org.1560.x6.nabble.com/Polygon-pattern-made-of-multiples-SVGs-tp5257478p5257800.html
Hi Geoffrey,
It’s definitely possible to get aligned patterns that are symetrical (i.e. a grid-like layout); I’m not so sure about offset as you have as your desired output. I’d suggest just experimenting and post back the parameters if you get it working.
Jonathan
---- On Tue, 22 Mar 2016 11:59:24 +0000 Geoffrey balmeg@anonymised.com wrote ----
Hi Andrea,
achieve:
<http://osgeo-org.1560.x6.nabble.com/file/n5257800/polygon.jpg>
have:
<http://osgeo-org.1560.x6.nabble.com/file/n5257800/pattern.jpg>
se:Fill
se:GraphicFill
se:Graphic
se:ExternalGraphic
se:Size12</se:Size>
</se:Graphic>
</se:GraphicFill>
</se:Fill>
18 9 18 9
se:Stroke
<se:SvgParameter name=“stroke”>#EA5471</se:SvgParameter>
<se:SvgParameter name=“stroke-width”>1</se:SvgParameter>
</se:Stroke>
se:Fill
se:GraphicFill
se:Graphic
se:ExternalGraphic
se:Size12</se:Size>
</se:Graphic>
</se:GraphicFill>
</se:Fill>
0 0 36 18
se:Stroke
</se:Stroke>
Could the problem be because I’m not taking account of the size of the svg ?
The svg I’m using is 10*10
http://pubads.g.doubleclick.net/gampad/clk?id=278785351&iu=/4140
I tried this quite hard, but I'm not able to have a better result than what I
posted above.
Any hint/help ?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Polygon-pattern-made-of-multiples-SVGs-tp5257478p5258312.html
Is this good enough?
<?xml version="1.0" encoding="UTF-8"?> Default Styler Default Styler triangle #fa8072 20 0 20 20 0 triangle #fa8072 20 20 0 0 20 first
Inline image 1
On Fri, Mar 25, 2016 at 12:02 PM, Geoffrey <balmeg@anonymised.com> wrote:
I tried this quite hard, but I’m not able to have a better result than what I
posted above.
Any hint/help ?
Ing. Andrea Aime
@geowolf
Technical Lead
