On Thu, Mar 10, 2016 at 3:16 PM, Geoffrey <balmeg@anonymised.com> wrote:
Hello,
I'm trying to style the stroke of a polygon with a SVG pattern.
If I only have one simple SVG symbol, this displays correctly, but if the
SVG is a composed from 2 or 3 different symbols, then when I try to render
a
complex polygon with this stroke, the layout is broken as it overflows and
show the whole pattern on the small lines that composed the polygon.
I hope I'm clear enough.
A screenshot would help.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
