[Geoserver-users] Polygons not filled anymore at certain zoom level
Hello,
I have a simple vector layer with polygons, which I fill using a SLD file.
It works at higher scales, but when I zoom in the polygons are not filled
anymore, but are just transparent or filled incompletely (as shown in the
screenshots). Any ideas what the problem could be?
The SLD:
  <FeatureTypeStyle>
        <Rule>
          <Name>rule1</Name>
          <PolygonSymbolizer>
            <Fill>
              <CssParameter name="fill">#FF0000</CssParameter>
            </Fill>
            <Stroke>
              <CssParameter name="stroke">#000000</CssParameter>
              <CssParameter name="stroke-width">1</CssParameter>
            </Stroke>
          </PolygonSymbolizer>
        </Rule>
</FeatureTypeStyle>
The screenshots:
<http://osgeo-org.1560.x6.nabble.com/file/n5261559/1.png&gt;
<http://osgeo-org.1560.x6.nabble.com/file/n5261559/2.png&gt;
<http://osgeo-org.1560.x6.nabble.com/file/n5261559/3.png&gt;
View this message in context: http://osgeo-org.1560.x6.nabble.com/Polygons-not-filled-anymore-at-certain-zoom-level-tp5261559.html
It could be a variant of this issue:
https://osgeo-org.atlassian.net/browse/GEOS-7417
Can you can try 2.9-beta and see if the issue shows up there too?
It is so far the only release with a fix, as multiple changes went in and it’s not clear
which one was actually fixing the problem.
On Sat, Apr 16, 2016 at 11:34 AM, hanshupe <paul.schneeweiss@anonymised.com> wrote:
Hello,
The SLD:
rule1 #FF0000 #000000 1
The screenshots:
<http://osgeo-org.1560.x6.nabble.com/file/n5261559/1.png>
<http://osgeo-org.1560.x6.nabble.com/file/n5261559/2.png>
<http://osgeo-org.1560.x6.nabble.com/file/n5261559/3.png>
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I just installed 2.9beta because the bugfix sounded so promising,
unfortunately it didn't fix the problem :frowning:
Any other ideas?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Polygons-not-filled-anymore-at-certain-zoom-level-tp5261559p5261567.html
I’d suggest to open a ticket at https://osgeo-org.atlassian.net/projects/GEOS, adding the style,
sample data and WMS requests sufficient to reproduce the issue.
If getting a fix is a matter of urgency, also consider looking at the code yourself and provide a pull request
(for GeoTools I’d say), or checking commercial support options.
On Sat, Apr 16, 2016 at 1:53 PM, hanshupe <paul.schneeweiss@anonymised.com> wrote:
unfortunately it didn’t fix the problem :frowning:
Any other ideas?
Ing. Andrea Aime
@geowolf
Technical Lead
The problem at the end was that the polygons were actually defined as lines
in our database. Thanks anyway!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Polygons-not-filled-anymore-at-certain-zoom-level-tp5261559p5261607.html
