Dear all,
I experienced the same problem: with GeoServer 2.14.1 the Print Plugin did not work anymore.
This solution outlined by Andrea solved it:
→ copy jts-core-1.14.0.jar
additionally to geoserver/webapps/geoserver/WEB-INF/lib
The lib
directory finally contains jts-core-1.14.0.jar
and jts-core-1.16.0.jar
side-by-side.
Maybe this helpful for someone.
Best wishes from snowy Austria,
Jakob
On Fri, Nov 30, 2018 at 6:29 PM Paul Wittle via Geoserver-users <geoserver-users@lists.sourceforge.net> wrote:
Â
I’m getting two errors with the mapFish printing plugin on version 2.14.1. Here are bits of the stack traces (I can send the rest if needed):
Â
ERROR: The remote server returned an error: (500) Internal Server Error.
CONTENT: Error while generating PDF:
java.lang.NoClassDefFoundError: com/vividsolutions/jts/geom/Geometry
at org.mapfish.print.map.renderers.TileRenderer.(TileRenderer.java:39)
at org.mapfish.print.map.readers.HTTPMapReader.render(HTTPMapReader.java:145)
at org.mapfish.print.map.readers.WMSMapReader.render(WMSMapReader.java:180)
For this one, could it be linked to the message here (https://docs.geoserver.org/stable/en/user/installation/upgrade.html)?
Â
Second error reads:
java.lang.NoClassDefFoundError: Could not initialize class org.mapfish.print.map.renderers.TileRenderer
Â
Do these look like bugs with that plugin or have I missed a configuration step whilst upgrading?
Â
Paul
“This e-mail is intended for the named addressee(s) only and may contain information about individuals or other sensitive information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this email in error, kindly disregard the content of the message and notify the sender immediately. Please be aware that all email may be subject to recording and/or monitoring in accordance with relevant legislation.”
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
