[Geoserver-users] possible bug
I wrote custom epsg string for mercator:
900915=PROJCS[“Google Mercator”,GEOGCS[“WGS 84”,DATUM[“World Geodetic System 1984”,SPHEROID[“WGS 84”, 6371000.0,297.85, AUTHORITY[“EPSG”,“7030”]],AUTHORITY[“EPSG”,“6326”]],PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],UNIT[“degree”, 0.017453292519943295],AXIS[“Geodetic latitude”, NORTH],AXIS[“Geodetic longitude”, EAST],AUTHORITY[“EPSG”,“4326”]],PROJECTION[“Mercator (1SP)”, AUTHORITY[“EPSG”,“9804”]],PARAMETER[“semi_major”, 6371000.0],PARAMETER[“semi_minor”, 6371000.0],PARAMETER[“latitude_of_origin”, 0.0],PARAMETER[“central_meridian”, 0.0],PARAMETER[“scale_factor”, 1.0],PARAMETER[“false_easting”, 0.0],PARAMETER[“false_northing”, 0.0],UNIT[“m”, 1.0],AXIS[“Easting”, EAST],AXIS[“Northing”, NORTH],AUTHORITY[“EPSG”,“900913”]]
Now if I send small bbox in request:
http://192.168.0.86:8080/geoserver/wms?LAYERS=test&FORMAT=image/jpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:900915&WIDTH=1559&HEIGHT=865&BBOX=1612817.5831249997,5782397.086614584,1612838.207395833,5782408.52984375&STYLES=
java eats all cpu power ,ram and vm crash.
Geoserver ver: 1.5.4.
With regards
Grega
