In trying to troubleshoot why the same data as a geoserver wms and postgis vector were shifted relative to one another, I picked up that they are projecting differently (26331 to 3875):
input point example:
"SRID=26331;POINT(542053.551 787930.307)"
in postgis (2.0):
"SRID=3857;POINT(376265.240380565 795675.534596811)"
in geoserver (2.2-SNAPSHOT):
"SRID=3857;POINT(376271.1415793335 790368.2841989407)"
proj4 text that postgis uses:
+proj=utm +zone=31 +ellps=clrk80 +towgs84=-92,-93,122,0,0,0,0 +units=m +no_defs
The WKT parameters that geoserver users:
I can't find them...I tried to follow these instructions http://docs.geoserver.org/latest/en/user/advanced/crshandling/manualepsg.html but they appear to be out of date since instead of EPSG.sql there is now EPSG.zip containing EPSG.script, EPSG.properties and EPSG.data. The latter which probably contains the projection definitions is binary.
postgis WKT for comparison:
PROJCS["Minna / UTM zone 31N",GEOGCS["Minna",DATUM["Minna",SPHEROID["Clarke 1880 (RGS)",6378249.145,293.465,AUTHORITY["EPSG","7012"]],TOWGS84[-92,-93,122,0,0,0,0],
AUTHORITY["EPSG","6263"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4263"]],
UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",3],
PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],AUTHORITY["EPSG","26331"],AXIS["Easting",
EAST],AXIS["Northing",NORTH]]
Any ideas which definition or transformation engine might be wrong?
regards
Gavin
Gavin Fleming
http://afrispatial.co.za
t: 0218630660
c: 0845965680
f: 0866164820
