I created a PostGIS table. I retrieve the feature through GeoServer
(1.3.0RC2). I configured GeoServer to use WGS84 (EPSG:4326).
I insert new features into the PostGIS table using the same CRS.
However when I try to display the features in uDig, I get a rendering
error. From the log (extract)
Caused by: org.geotools.ows.ServiceException:
org.geotools.data.DataSourceException: Could not count
at
org.geotools.xml.XMLSAXHandler.endElement(XMLSAXHandler.java:229)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(
Unknown Source)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanEnd
Element(Unknown Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$F
ragmentContentDispatcher.dispatch(Unknown Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.s
canDocument(Unknown Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unkn
own Source)
at
own Source)
at
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unkno
wn Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at
org.geotools.xml.DocumentFactory.getInstance(DocumentFactory.java:139)
at
org.geotools.data.wfs.WFSFeatureReader.run(WFSFeatureReader.java:123)
Curiously: if I change the table to use CRS number 0 (Unknown) and enter
the features with CRS of 0 everything displays nicely in uDig!
I remember reading somewhere that geoserver ignores the CRS code in
PostGIS; but considering my experiences this may not be the entire
truth.
Anybody knows what is going on?
Willem Nieuwenhuis
System Developer
IT-Department, Sector Remote Sensing & GIS
Tel: 458
Some hints:
- When you installed postgis, did you load lwpostgis.sql and
spatial_ref_sys.sql scripts?
- There is a record in spatial_ref_sys table with value "4326" in "srid" field
Eduin
at
at
Unknown Source)
at
at
at
at
own Source)
at
own Source)
at
Source)
at
wn Source)
at
at
truth.
Willem Nieuwenhuis
System Developer
Tel: 458
Eduin Yezid Carrillo Vega
GIS Specialist
http://eduinyezid.carrillovega.com
http://sig.cas.gov.co/~yecarrillo
__________________________________________________
Correo Yahoo!
Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
Regístrate ya - http://correo.espanol.yahoo.com/
Hmmm... The first thing to do would be to upgrade GeoServer, as the problem may have already been fixed. The Could not count exception is a bit odd, since I don't think WFS DataStore should be trying to count, although maybe it's trying to go through the whole list.
I don't think the CRS in postgis is entirely ignored any more. And when you configure a CRS it should automatically show up in the FeatureType editor.
So please upgrade to GeoServer 1.3.1, and also try to get a more complete stack trace, as there should be an underlying reason that it couldn't count. Like there should be a 'causedBy' somewhere buried down there I believe.
best regards,
Chris
at
at
Unknown Source)
at
at
at
at
own Source)
at
own Source)
at
Source)
at
wn Source)
at
at
truth.
Willem Nieuwenhuis
System Developer
Tel: 458
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
!DSPAM:1003,44a1051e31911665516417!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
