Hi Ben,
Thanks for your response, please find below the full stack trace and logs when GeoServer is started.
Best Regards,
Ryan
2013-05-31 09:46:43,776 DEBUG [org.geoserver.logging] - Logging output to file 'C:\Program Files (x86)\GeoServer 2.3.2\data_dir\logs\geoserver.log'
2013-05-31 09:46:43,777 DEBUG [org.geoserver.logging] - FINISHED CONFIGURING GEOSERVER LOGGING -------------------------
2013-05-31 09:46:45,246 WARN [org.springframework.beans.factory.config.CustomEditorConfigurer] - Passing PropertyEditor instances into CustomEditorConfigurer is deprecated: use PropertyEditorRegistrars or PropertyEditor class names instead. Offending key [org.geotools.util.Version; offending editor instance: org.geoserver.platform.util.VersionPropertyEditor@...5622...
2013-05-31 09:46:45,556 INFO [org.vfny.geoserver.global] -
- GEOSERVER_DATA_DIR: C:\Program Files (x86)\GeoServer 2.3.2\data_dir
2013-05-31 09:46:45,667 INFO [org.geoserver] - Loaded style 'burg'
2013-05-31 09:46:45,668 INFO [org.geoserver] - Loaded style 'capitals'
2013-05-31 09:46:45,669 INFO [org.geoserver] - Loaded style 'cite_lakes'
2013-05-31 09:46:45,670 INFO [org.geoserver] - Loaded style 'dem'
2013-05-31 09:46:45,670 INFO [org.geoserver] - Loaded style 'giant_polygon'
2013-05-31 09:46:45,671 INFO [org.geoserver] - Loaded style 'grass'
2013-05-31 09:46:45,672 INFO [org.geoserver] - Loaded style 'green'
2013-05-31 09:46:45,673 INFO [org.geoserver] - Loaded style 'line'
2013-05-31 09:46:45,674 INFO [org.geoserver] - Loaded style 'poi'
2013-05-31 09:46:45,679 INFO [org.geoserver] - Loaded style 'point'
2013-05-31 09:46:45,679 INFO [org.geoserver] - Loaded style 'polygon'
2013-05-31 09:46:45,691 INFO [org.geoserver] - Loaded style 'poly_landmarks'
2013-05-31 09:46:45,701 INFO [org.geoserver] - Loaded style 'pophatch'
2013-05-31 09:46:45,701 INFO [org.geoserver] - Loaded style 'population'
2013-05-31 09:46:45,701 INFO [org.geoserver] - Loaded style 'rain'
2013-05-31 09:46:45,701 INFO [org.geoserver] - Loaded style 'raster'
2013-05-31 09:46:45,701 INFO [org.geoserver] - Loaded style 'restricted'
2013-05-31 09:46:45,701 INFO [org.geoserver] - Loaded style 'simple_roads'
2013-05-31 09:46:45,701 INFO [org.geoserver] - Loaded style 'simple_streams'
2013-05-31 09:46:45,701 INFO [org.geoserver] - Loaded style 'tiger_roads'
2013-05-31 09:46:45,701 INFO [org.geoserver] - Loaded default workspace bathymetry
2013-05-31 09:46:45,711 INFO [org.geoserver] - Loaded workspace 'bathymetry'
2013-05-31 09:46:45,711 INFO [org.geoserver] - Loaded workspace 'cite'
2013-05-31 09:46:45,711 INFO [org.geoserver] - Loaded workspace 'it.geosolutions'
2013-05-31 09:46:45,711 INFO [org.geoserver] - Loaded workspace 'nurc'
2013-05-31 09:46:45,711 INFO [org.geoserver] - Loaded workspace 'sde'
2013-05-31 09:46:45,721 INFO [org.geoserver] - Loaded workspace 'sf'
2013-05-31 09:46:45,721 INFO [org.geoserver] - Loaded workspace 'tiger'
2013-05-31 09:46:45,721 INFO [org.geoserver] - Loaded workspace 'topp'
2013-05-31 09:46:46,084 INFO [org.geoserver] - Loaded store 'bathymetry_data_source', enabled
2013-05-31 09:46:46,089 INFO [org.geoserver] - Loaded data store 'bathymetry_data_source'
2013-05-31 09:46:51,412 WARN [org.geoserver] - Error connecting to 'bathymetry_data_source'. Disabling.
2013-05-31 09:46:51,412 INFO [org.geoserver] -
java.io.IOException
at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:579)
at org.geoserver.catalog.impl.DataStoreInfoImpl.getDataStore(DataStoreInfoImpl.java:37)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:354)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:226)
at org.geoserver.config.DefaultGeoServerLoader.loadCatalog(DefaultGeoServerLoader.java:46)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:114)
at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitialization(GeoServerLoaderProxy.java:58)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:394)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1448)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:322)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:106)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:630)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:284)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:464)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:385)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:284)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:22)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
Caused by: java.lang.RuntimeException: java.net.ConnectException: Connection refused: connect
at org.geotools.xml.AppSchemaCache.download(AppSchemaCache.java:282)
at org.geotools.xml.AppSchemaCache.download(AppSchemaCache.java:212)
at org.geotools.xml.AppSchemaCache.download(AppSchemaCache.java:202)
at org.geotools.xml.AppSchemaCache.resolveLocation(AppSchemaCache.java:307)
at org.geotools.xml.AppSchemaResolver.resolve(AppSchemaResolver.java:201)
at org.geotools.data.complex.config.EmfComplexFeatureReader.findSchemaNamespace(EmfComplexFeatureReader.java:138)
at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.parseGmlSchemas(AppSchemaDataAccessConfigurator.java:563)
at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.buildMappings(AppSchemaDataAccessConfigurator.java:196)
at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.buildMappings(AppSchemaDataAccessConfigurator.java:175)
at org.geotools.data.complex.AppSchemaDataAccessFactory.createDataStore(AppSchemaDataAccessFactory.java:96)
at org.vfny.geoserver.util.DataStoreUtils.getDataAccess(DataStoreUtils.java:107)
at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:539)
... 93 more
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
at org.geotools.xml.AppSchemaCache.download(AppSchemaCache.java:232)
... 104 more
2013-05-31 09:46:51,626 INFO [org.geoserver] - Loaded feature type 'townssurvey_poly', enabled
2013-05-31 09:46:51,658 INFO [org.geoserver] - Loaded feature type 'bathymetry_data_source'
2013-05-31 09:46:51,678 INFO [org.geoserver] - Loaded layer 'townssurvey_poly'
2013-05-31 09:46:51,700 INFO [org.geoserver] - Loaded store 'arcGridSample', enabled
2013-05-31 09:46:51,708 INFO [org.geoserver] - Loaded coverage store 'arcGridSample'
2013-05-31 09:46:52,052 WARN [org.geotools.referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984", SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0], UNIT["degree", 0.017453292519943295]], PROJECTION["Mercator_1SP_Google"], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","54004"]]
2013-05-31 09:46:52,159 INFO [org.geoserver] - Loaded coverage 'Arc_Sample', enabled
2013-05-31 09:46:52,169 INFO [org.geoserver] - Loaded coverage 'arcGridSample'
2013-05-31 09:46:52,849 INFO [org.geoserver] - Loaded layer 'Arc_Sample'
2013-05-31 09:46:52,856 INFO [org.geoserver] - Loaded store 'img_sample2', disabled
2013-05-31 09:46:52,857 INFO [org.geoserver] - Loaded coverage store 'img_sample2'
2013-05-31 09:46:53,086 INFO [org.geoserver] - Loaded coverage 'Pk50095', disabled
2013-05-31 09:46:53,087 INFO [org.geoserver] - Loaded coverage 'img_sample2'
2013-05-31 09:46:53,089 INFO [org.geoserver] - Loaded layer 'Pk50095'
2013-05-31 09:46:53,097 INFO [org.geoserver] - Loaded store 'mosaic', enabled
2013-05-31 09:46:53,098 INFO [org.geoserver] - Loaded coverage store 'mosaic'
2013-05-31 09:46:53,103 INFO [org.geoserver] - Loaded coverage 'mosaic', enabled
2013-05-31 09:46:53,104 INFO [org.geoserver] - Loaded coverage 'mosaic'
2013-05-31 09:46:53,156 WARN [org.geotools.gce.imagemosaic.catalog] - BBOXFilterExtractor::extractBasicProperties(): passed typename is null, using: mosaic
2013-05-31 09:46:53,604 WARN [class org.geotools.gce.imagemosaic.Utils] - Unable to find sample image for path C:\Program Files (x86)\GeoServer 2.3.2\data_dir\coverages\mosaic_sample\sample_image
2013-05-31 09:46:53,604 WARN [org.geotools.gce.imagemosaic] - Unable to find sample image for path file:/C:/Program%20Files%20(x86)/GeoServer%202.3.2/data_dir/coverages/mosaic_sample/mosaic.shp
2013-05-31 09:46:53,605 INFO [org.geoserver] - Loaded layer 'mosaic'
2013-05-31 09:46:53,619 INFO [org.geoserver] - Loaded store 'worldImageSample', enabled
2013-05-31 09:46:53,620 INFO [org.geoserver] - Loaded coverage store 'worldImageSample'
2013-05-31 09:46:53,624 INFO [org.geoserver] - Loaded coverage 'Img_Sample', enabled
2013-05-31 09:46:53,624 INFO [org.geoserver] - Loaded coverage 'worldImageSample'
2013-05-31 09:46:53,644 INFO [org.geoserver] - Loaded layer 'Img_Sample'
2013-05-31 09:46:53,680 INFO [org.geoserver] - Loaded store 'sf', enabled
2013-05-31 09:46:53,681 INFO [org.geoserver] - Loaded data store 'sf'
2013-05-31 09:46:53,736 INFO [org.geoserver] - Loaded feature type 'archsites', enabled
2013-05-31 09:46:53,737 INFO [org.geoserver] - Loaded feature type 'sf'
2013-05-31 09:46:53,738 INFO [org.geoserver] - Loaded layer 'archsites'
2013-05-31 09:46:53,746 INFO [org.geoserver] - Loaded feature type 'bugsites', enabled
2013-05-31 09:46:53,747 INFO [org.geoserver] - Loaded feature type 'sf'
2013-05-31 09:46:53,748 INFO [org.geoserver] - Loaded layer 'bugsites'
2013-05-31 09:46:53,774 INFO [org.geoserver] - Loaded feature type 'restricted', enabled
2013-05-31 09:46:53,774 INFO [org.geoserver] - Loaded feature type 'sf'
2013-05-31 09:46:53,774 INFO [org.geoserver] - Loaded layer 'restricted'
2013-05-31 09:46:53,774 INFO [org.geoserver] - Loaded feature type 'roads', enabled
2013-05-31 09:46:53,774 INFO [org.geoserver] - Loaded layer 'roads'
2013-05-31 09:46:53,784 INFO [org.geoserver] - Loaded feature type 'streams', enabled
2013-05-31 09:46:53,784 INFO [org.geoserver] - Loaded feature type 'sf'
2013-05-31 09:46:53,784 INFO [org.geoserver] - Loaded layer 'streams'
2013-05-31 09:46:53,794 INFO [org.geoserver] - Loaded store 'sfdem', enabled
2013-05-31 09:46:53,794 INFO [org.geoserver] - Loaded coverage store 'sfdem'
2013-05-31 09:46:53,794 INFO [org.geoserver] - Loaded coverage 'sfdem', enabled
2013-05-31 09:46:53,946 INFO [org.geoserver] - Loaded layer 'sfdem'
2013-05-31 09:46:53,955 INFO [org.geoserver] - Loaded store 'nyc', enabled
2013-05-31 09:46:53,956 INFO [org.geoserver] - Loaded data store 'nyc'
2013-05-31 09:46:53,975 INFO [org.geoserver] - Loaded feature type 'giant_polygon', enabled
2013-05-31 09:46:53,976 INFO [org.geoserver] - Loaded feature type 'nyc'
2013-05-31 09:46:53,977 INFO [org.geoserver] - Loaded layer 'giant_polygon'
2013-05-31 09:46:53,978 INFO [org.geoserver] - Loaded feature type 'poi', enabled
2013-05-31 09:46:53,979 INFO [org.geoserver] - Loaded feature type 'nyc'
2013-05-31 09:46:53,980 INFO [org.geoserver] - Loaded layer 'poi'
2013-05-31 09:46:53,982 INFO [org.geoserver] - Loaded feature type 'poly_landmarks', enabled
2013-05-31 09:46:53,982 INFO [org.geoserver] - Loaded feature type 'nyc'
2013-05-31 09:46:53,984 INFO [org.geoserver] - Loaded layer 'poly_landmarks'
2013-05-31 09:46:54,006 INFO [org.geoserver] - Loaded feature type 'tiger_roads', enabled
2013-05-31 09:46:54,006 INFO [org.geoserver] - Loaded feature type 'nyc'
2013-05-31 09:46:54,006 INFO [org.geoserver] - Loaded layer 'tiger_roads'
2013-05-31 09:46:54,016 INFO [org.geoserver] - Loaded store 'states_shapefile', enabled
2013-05-31 09:46:54,016 INFO [org.geoserver] - Loaded data store 'states_shapefile'
2013-05-31 09:46:54,026 INFO [org.geoserver] - Loaded feature type 'states', enabled
2013-05-31 09:46:54,026 INFO [org.geoserver] - Loaded feature type 'states_shapefile'
2013-05-31 09:46:54,026 INFO [org.geoserver] - Loaded layer 'states'
2013-05-31 09:46:54,036 INFO [org.geoserver] - Loaded store 'taz_shapes', enabled
2013-05-31 09:46:54,036 INFO [org.geoserver] - Loaded data store 'taz_shapes'
2013-05-31 09:46:54,056 INFO [org.geoserver] - Loaded feature type 'tasmania_cities', enabled
2013-05-31 09:46:54,056 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
2013-05-31 09:46:54,066 INFO [org.geoserver] - Loaded layer 'tasmania_cities'
2013-05-31 09:46:54,066 INFO [org.geoserver] - Loaded feature type 'tasmania_roads', enabled
2013-05-31 09:46:54,066 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
2013-05-31 09:46:54,066 INFO [org.geoserver] - Loaded layer 'tasmania_roads'
2013-05-31 09:46:54,066 INFO [org.geoserver] - Loaded feature type 'tasmania_state_boundaries', enabled
2013-05-31 09:46:54,076 INFO [org.geoserver] - Loaded layer 'tasmania_state_boundaries'
2013-05-31 09:46:54,076 INFO [org.geoserver] - Loaded feature type 'tasmania_water_bodies', enabled
2013-05-31 09:46:54,076 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
2013-05-31 09:46:54,076 INFO [org.geoserver] - Loaded layer 'tasmania_water_bodies'
2013-05-31 09:46:54,076 WARN [org.geoserver] - Ignoring store directory 'tut_data_source'
2013-05-31 09:46:54,086 INFO [org.geoserver] - Loaded layer group 'spearfish'
2013-05-31 09:46:54,096 INFO [org.geoserver] - Loaded layer group 'tasmania'
2013-05-31 09:46:54,096 INFO [org.geoserver] - Loaded layer group 'tiger-ny'
2013-05-31 09:46:54,462 INFO [org.geoserver.gwc.layer] - Initializing GWC configuration based on GeoServer's Catalog
2013-05-31 09:46:54,463 INFO [org.geoserver.gwc.layer] - GeoServer TileLayer store base directory is: C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers
2013-05-31 09:46:54,464 INFO [org.geoserver.gwc.layer] - Loading tile layers from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers
2013-05-31 09:46:54,464 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerGroupInfoImpl--570ae188_124761b8d78_-7fab.xml
2013-05-31 09:46:54,476 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'spearfish'
2013-05-31 09:46:54,476 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerGroupInfoImpl--570ae188_124761b8d78_-7fac.xml
2013-05-31 09:46:54,477 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'tasmania'
2013-05-31 09:46:54,477 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerGroupInfoImpl--570ae188_124761b8d78_-7fad.xml
2013-05-31 09:46:54,478 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'tiger-ny'
2013-05-31 09:46:54,478 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--4a9eec43_132d48aac79_-7fff.xml
2013-05-31 09:46:54,481 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'nurc:mosaic'
2013-05-31 09:46:54,481 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fae.xml
2013-05-31 09:46:54,482 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'nurc:Img_Sample'
2013-05-31 09:46:54,483 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fb0.xml
2013-05-31 09:46:54,483 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'sf:sfdem'
2013-05-31 09:46:54,483 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fb4.xml
2013-05-31 09:46:54,484 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'nurc:Pk50095'
2013-05-31 09:46:54,484 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fb6.xml
2013-05-31 09:46:54,488 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'nurc:Arc_Sample'
2013-05-31 09:46:54,489 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fb8.xml
2013-05-31 09:46:54,489 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'topp:tasmania_water_bodies'
2013-05-31 09:46:54,490 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fba.xml
2013-05-31 09:46:54,490 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'topp:tasmania_state_boundaries'
2013-05-31 09:46:54,490 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fbc.xml
2013-05-31 09:46:54,492 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'topp:tasmania_roads'
2013-05-31 09:46:54,492 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fbe.xml
2013-05-31 09:46:54,493 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'topp:tasmania_cities'
2013-05-31 09:46:54,494 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fc0.xml
2013-05-31 09:46:54,494 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'topp:states'
2013-05-31 09:46:54,494 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fc2.xml
2013-05-31 09:46:54,495 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'sf:streams'
2013-05-31 09:46:54,496 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fc4.xml
2013-05-31 09:46:54,497 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'sf:roads'
2013-05-31 09:46:54,497 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fc6.xml
2013-05-31 09:46:54,498 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'sf:restricted'
2013-05-31 09:46:54,498 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fc8.xml
2013-05-31 09:46:54,499 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'sf:bugsites'
2013-05-31 09:46:54,499 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fca.xml
2013-05-31 09:46:54,507 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'sf:archsites'
2013-05-31 09:46:54,507 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fcc.xml
2013-05-31 09:46:54,509 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'tiger:tiger_roads'
2013-05-31 09:46:54,510 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fce.xml
2013-05-31 09:46:54,510 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'tiger:poly_landmarks'
2013-05-31 09:46:54,510 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fd0.xml
2013-05-31 09:46:54,511 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'tiger:poi'
2013-05-31 09:46:54,511 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fd2.xml
2013-05-31 09:46:54,512 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'tiger:giant_polygon'
2013-05-31 09:46:54,513 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl-39154e6b_13ef0ec49f8_-7ffc.xml
2013-05-31 09:46:54,513 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'bathymetry:townssurvey_poly'
2013-05-31 09:46:54,547 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fae.xml
2013-05-31 09:46:54,554 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fce.xml
2013-05-31 09:46:54,555 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--4a9eec43_132d48aac79_-7fff.xml
2013-05-31 09:46:54,556 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fbe.xml
2013-05-31 09:46:54,561 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fca.xml
2013-05-31 09:46:54,562 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fbc.xml
2013-05-31 09:46:54,565 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fcc.xml
2013-05-31 09:46:54,566 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fba.xml
2013-05-31 09:46:54,566 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerGroupInfoImpl--570ae188_124761b8d78_-7fad.xml
2013-05-31 09:46:54,567 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerGroupInfoImpl--570ae188_124761b8d78_-7fac.xml
2013-05-31 09:46:54,568 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerGroupInfoImpl--570ae188_124761b8d78_-7fab.xml
2013-05-31 09:46:54,578 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fb4.xml
2013-05-31 09:46:54,578 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fb6.xml
2013-05-31 09:46:54,588 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fc8.xml
2013-05-31 09:46:54,588 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fb8.xml
2013-05-31 09:46:54,588 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl-39154e6b_13ef0ec49f8_-7ffc.xml
2013-05-31 09:46:54,588 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fc6.xml
2013-05-31 09:46:54,588 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fc4.xml
2013-05-31 09:46:54,588 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fd2.xml
2013-05-31 09:46:54,588 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fc2.xml
2013-05-31 09:46:54,588 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fc0.xml
2013-05-31 09:46:54,588 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fb0.xml
2013-05-31 09:46:54,588 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Program Files (x86)\GeoServer 2.3.2\data_dir\gwc-layers\LayerInfoImpl--570ae188_124761b8d78_-7fd0.xml
2013-05-31 09:46:54,588 INFO [org.geoserver.gwc.layer] - GWC configuration based on GeoServer's Catalog loaded successfuly
2013-05-31 09:46:54,778 INFO [org.geoserver] - Loaded service 'wcs', enabled
2013-05-31 09:46:54,808 INFO [org.geoserver] - Loaded service 'wfs', enabled
2013-05-31 09:46:54,860 INFO [org.geoserver] - Loaded service 'wms', enabled
2013-05-31 09:46:54,870 INFO [org.geoserver.gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
2013-05-31 09:46:54,880 DEBUG [org.geoserver.gwc.config] - GWC GeoServer specific configuration loaded from gwc-gs.xml
2013-05-31 09:46:54,951 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/gwc/service/**] onto handler 'dispatcher'
2013-05-31 09:46:55,195 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/ows/**] onto handler 'dispatcher'
2013-05-31 09:46:55,195 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler 'dispatcher'
2013-05-31 09:46:55,210 INFO [org.geoserver] - GeoServer configuration lock is enabled
2013-05-31 09:46:55,380 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler 'dispatcher'
2013-05-31 09:46:55,381 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/wcs/**] onto handler 'dispatcher'
2013-05-31 09:46:56,180 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/wfs/*] onto handler 'dispatcher'
2013-05-31 09:46:56,180 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/TestWfsPost] onto handler 'wfsTestServlet'
2013-05-31 09:46:56,180 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/wfs] onto handler 'dispatcher'
2013-05-31 09:46:56,517 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/wms/*] onto handler 'dispatcher'
2013-05-31 09:46:56,517 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/wms] onto handler 'dispatcher'
2013-05-31 09:46:56,765 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/kml] onto handler 'dispatcher'
2013-05-31 09:46:56,766 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/kml/*] onto handler 'dispatcher'
2013-05-31 09:46:56,767 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/animate] onto handler 'dispatcher'
2013-05-31 09:46:56,767 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/animate/*] onto handler 'dispatcher'
2013-05-31 09:46:57,207 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - Line 1: /**:GET=ADMIN
2013-05-31 09:46:57,208 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /**:GET firstColonIndex= 3
2013-05-31 09:46:57,208 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /**:GET antPath= /** methods= GET
2013-05-31 09:46:57,208 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - methodList = [GET]
2013-05-31 09:46:57,210 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Added Ant path: /**; attributes: [ADMIN], httpMethods: [GET]
2013-05-31 09:46:57,210 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - Line 1: /**:POST,DELETE,PUT=ADMIN
2013-05-31 09:46:57,210 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /**:POST,DELETE,PUT firstColonIndex= 3
2013-05-31 09:46:57,210 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /**:POST,DELETE,PUT antPath= /** methods= POST,DELETE,PUT
2013-05-31 09:46:57,211 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - methodList = [POST, DELETE, PUT]
2013-05-31 09:46:57,211 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Added Ant path: /**; attributes: [ADMIN], httpMethods: [POST, DELETE, PUT]
-----Original Message-----
From: Ben Caradoc-Davies [mailto:Ben.Caradoc-Davies@…367…]
Sent: 31 May 2013 05:17
To: Ryan Moody
Cc: geoserver-users@lists.sourceforge.net; Ian Turton; Neil Kirk
Subject: Re: [Geoserver-users] PostGIS Connection Refused
Ryan,
I can't see anything obvious. Can we please see the full stack trace from your logs?
Kind regards,
Ben.
On 30/05/13 18:35, Ryan Moody wrote:
Hello,
I would be very grateful if someone could assist me with the following
problem.
I have GeoServer 2.3.2 running on my local machine, and have been able
to get it to publish a layer using a PostGIS database as the data
store, which is also running on my local machine.
The working datastore.xml is as follows:
<dataStore>
<id>DataStoreInfoImpl--6d343d73:13ef4ab8649:-8000</id>
<name>MyName</name>
<description>MyDescription</description>
<type>PostGIS</type>
<enabled>true</enabled>
<workspace>
<id>WorkspaceInfoImpl-39154e6b:13ef0ec49f8:-8000</id>
</workspace>
<connectionParameters>
<entry key="port">5432</entry>
<entry key="Connection timeout">20</entry>
<entry key="passwd"> MyPassword </entry>
<entry key="dbtype">postgis</entry>
<entry key="host">localhost</entry>
<entry key="validate connections">true</entry>
<entry key="encode functions">false</entry>
<entry key="max connections">10</entry>
<entry key="database">MyDatabase </entry>
<entry key="namespace">MyNamespace </entry>
<entry key="schema">public</entry>
<entry key="Loose bbox">true</entry>
<entry key="Expose primary keys">false</entry>
<entry key="fetch size">1000</entry>
<entry key="Max open prepared statements">50</entry>
<entry key="preparedStatements">false</entry>
<entry key="Estimated extends">true</entry>
<entry key="user">MyUser</entry>
<entry key="min connections">1</entry>
</connectionParameters>
<__default>false</__default>
</dataStore>
I am now trying to reconfigure the data store to use GeoServer’s
app-schema plugin, referring to an XML mapping file that provides the
PostGIS database connection details.
The modified datastore.xml is as follows:
<dataStore>
<id> DataStoreInfoImpl--6d343d73:13ef4ab8649:-8000</id>
<name> MyName </name>
<description> MyDescription </description>
<workspace>
<id> WorkspaceInfoImpl-39154e6b:13ef0ec49f8:-8000</id>
</workspace>
<entry key="namespace">MyNamespace</entry>
<entry
key="url">file:workspaces/path/to/MyMappingFile.xml</entry>
<entry key="dbtype">app-schema</entry>
</dataStore>
And the XML mapping file I have defined is as follows:
<as:AppSchemaDataAccess xmlns:as="http://www.geotools.org/app-schema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.geotools.org/app-schema
AppSchemaDataAccess.xsd">
<namespaces>
(…some namespaces…)
</namespaces>
<sourceDataStores>
<DataStore>
<id>datastore</id>
<parameters>
<Parameter>
<name>dbtype</name>
<value>postgis</value>
</Parameter>
<Parameter>
<name>host</name>
<value>localhost</value>
</Parameter>
<Parameter>
<name>port</name>
<value>5432</value>
</Parameter>
<Parameter>
<name>database</name>
<value>MyDatabase </value>
</Parameter>
<Parameter>
<name>user</name>
<value>MyUser </value>
</Parameter>
<Parameter>
<name>passwd</name>
<value>MyPassword</value>
</Parameter>
</parameters>
</DataStore>
</sourceDataStores>
<targetTypes>
(…some target types…)
</targetTypes>
<typeMappings>
(…some type mappings…)
</typeMappings>
</as:AppSchemaDataAccess>
Unfortunately, when I restart GeoServer, I get a Java exception
“Connection refused: connect” when it attempts to connect to my data
source. I have confirmed that I am able to connect to my PostGIS
database via pgAdmin, and I have set listen_addresses=’*’ in the
postgresql.conf file. A Google search suggested to check my firewall
settings, but the firewall shouldn’t be an issue as GeoServer and the
PostGIS database are both running on my local machine. I have
double-checked that the datastore parameters in the XML mapping file,
especially the user and passwd, are correct.
If anyone can suggest how I may be able to address this issue, I’d be
most appreciative
Ryan
-------- Introducing AppDynamics Lite, a free troubleshooting tool for
Java/.NET Get 100% visibility into your production application - at no
cost.
Code-level diagnostics for performance bottlenecks with <2% overhead
Download for free and get started troubleshooting in minutes.
http://p.sf.net/sfu/appdyn_d2d_ap1
Geoserver-users mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@...367...> Software Engineer CSIRO Earth Science and Resource Engineering Australian Resources Research Centre
