[Geoserver-users] PostGIS data stores are lost on Upgrade 2.2 to 2.7
we're using GeoServer 2.2 (Java 6) for a long time. We use it for WFS only and mostly on PostGIS Database.
Our Client is Mapbender 2.7.
I plan to Upgrade to actual stable GeoServer 2.7 (Java 7).
When GeoServer 2.7 starts first time with the external data-directory from GeoServer 2.2 it throws some exceptions.
From "/data/workspaces/MyWorkspace/MyDataStore/MyLayer/" most of "MyDataStore"s disappear. Also "MyLayer"s depending on it are lost.
Only 1 data store survives, which has Shapefiles and not PostGIS as source.
Theres a lot of logging but mostly not usefull for a Non-Java-Programmer. Maybe this helps:
<log>
WARN [org.geoserver] - Failed to load data store 'adressen'
com.thoughtworks.xstream.converters.ConversionException: null : null
---- Debugging information ----
cause-exception : org.jasypt.exceptions.EncryptionOperationNotPossibleException
cause-message : null
</log>
It seems that from 2.2 to 2.7 the range is too wide.
Will it be usefull to upgrade whith a step between to get it compatible? Which Version?
Can I prepare the XML-Files in "/data/workspaces/MyWorkspace/" to be compatible? (For Example delete encrypted Password-Tag and set it new by gui?)
It seems to be easyer to confirurate all WFS new then to Upgrade step by step for all (main?-)releases.
Best regards
Frank Jäger
Hum… looks like an issue with database encrypted passwords.
I thought that was going to be supported automatically, but apparently not on such a long jump.
Christian, cc’ed, worked on password encryption, he might have a clue
On Tue, Aug 25, 2015 at 9:38 AM, Jäger, Frank (KRZ) <F.Jaeger@anonymised.com> wrote:
we’re using GeoServer 2.2 (Java 6) for a long time. We use it for WFS only and mostly on PostGIS Database.
From “/data/workspaces/MyWorkspace/MyDataStore/MyLayer/” most of "MyDataStore"s disappear. Also "MyLayer"s depending on it are lost.
WARN [org.geoserver] - Failed to load data store 'adressen' com.thoughtworks.xstream.converters.ConversionException: null : null ---- Debugging information ---- cause-exception : org.jasypt.exceptions.EncryptionOperationNotPossibleException cause-message : null
Can I prepare the XML-Files in “/data/workspaces/MyWorkspace/” to be compatible? (For Example delete encrypted Password-Tag and set it new by gui?)
Best regards
Frank Jäger
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I found this work-around:
- Delete the line "<entry key="passwd">crypt2: ..." in all files _/data/workspaces/MyWorkspace/MyDatastore/datastore.xml
- Start Geoserver
- The datastores will be disabled
- Enable and configure database-password in GUI
- This will write a line " key="passwd">crypt1:"
Frank
Von: andrea.aime@...84... [mailto:andrea.aime@…84…] Im Auftrag von Andrea Aime
Gesendet: Dienstag, 25. August 2015 10:13
An: Jäger, Frank (KRZ); Christian Mueller
Betreff: Re: [Geoserver-users] PostGIS data stores are lost on Upgrade 2.2 to 2.7
Hum... looks like an issue with database encrypted passwords.
On Tue, Aug 25, 2015 at 9:38 AM, Jäger, Frank (KRZ) <F.Jaeger@...7209...> wrote:
... most of "MyDataStore"s disappear.
<log>
..</log>
