[Geoserver-users] PostGIS rasters without mosaicing?
Hello all,
I’ve an application for which I need to store and display fairly low-res (400x400) rasters. I’d also like a Web app to be able to do various calculations on them, so it helps if they’re in a database rather than stored as individual files (there will be at least one new raster every day).
I know that the ImageMosaic JDBC plugin can display PostGIS rasters, but that’s a ton of setup overhead and complexity that I don’t need — I do not need or want a pyramid of these rasters.
Any simple way forward? As it is, I’m ready to just accumulate files and deal with the calculations when and if.
rw
AFAIK there is no simpler approach.
Christian
On Wed, May 25, 2016 at 11:11 PM, RICK WAYNE <fewayne@anonymised.com> wrote:
Hello all,
rw
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition of MDM
restrictions. Mobile Device Manager Plus allows you to control only the
apps on BYO-devices by containerizing them, leaving personal data untouched!
https://ad.doubleclick.net/ddm/clk/304595813;131938128;j
Geoserver-users mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Hi Rick,
you’re not the first to find the imagemosaic jdbc module too hard to configure.
Some time ago a colleague of mine prepared a small community module that helps some in setting up
its configuration for pgraster:
http://docs.geoserver.org/latest/en/user/community/pgraster/pgraster.html
Being a community module, it is built only for nightly builds, and not officially supported,
but you can give it a try:
http://ares.boundlessgeo.com/geoserver/2.8.x/community-latest/
Postgis raster is a significant case enough that it would probably deserve an easy custom
store built for it, but we haven’t seen funding towards making that possible yet
Hello all,
rw
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
