Hi
I am running a recent build of geoserver, and I am having trouble getting
the WFS to publish my 'static strings in a view'.
When I add the layer it doesn't ever show the table columns in the feature
detector.
---EDIT (found answer....) ----
Table was created invalidly. static strings as column in postgres.
Creating a view using ['static string' as column_name] is not the same as
creating ['static string'::text as column_name]. If you dont define the
'type' then geoserver cant read the type. *why cant it read my mind...*
Geoserver knew that there was content in the table that was 'invalid' but
didn't tell me I was a bit silly, it just hid the invalid content.
So, in summary - there is no need to post this, but it may help others that
are as silly as me.
Terry
Details
Version 2.4-SNAPSHOT
Git Revision 717b73a5636c4466af2b4b3c5111f24dc11a6e00
Build Date 20130214-0950
GeoTools Version 10-SNAPSHOT (rev
5cf4d998a6d5d65eb395772ad7ce65cd395cef17)
GeoWebCache Version 1.4-SNAPSHOT (rev
master/83b284b341ef25fe89adf2eb7858991defa64e57)
View this message in context: http://osgeo-org.1560.n6.nabble.com/Postgis-Views-static-strings-simple-features-tp5037404.html
