Hi
Can someone tell me what privileges a PostgreSQL account needs for
GeoServer needs to work?
as GeoServer is not updating or inserting data would this be enough
GRANT SELECT to geo_user on Table1; // Read Only
Thanx
Holly
Hi
Thanx
Holly
Hi Holly,
Those are all the permissions my Oracle user has and it works fine (also read-only). I’d be very surprised if PostGreSQL was that different.Regards,
Jonathan
On 7 February 2013 09:41, Holly Gibons <holyg1986@anonymised.com84…> wrote:
Hi
GeoServer needs to work?as GeoServer is not updating or inserting data would this be enough
Thanx
Holly
Free Next-Gen Firewall Hardware Offer
Buy your Sophos next-gen firewall before the end March 2013
and get the hardware for free! Learn more.
http://p.sf.net/sfu/sophos-d2d-feb
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
