Well in my opinion posting on stackoverflow you can probably reach a larger audience.
But on this list your post will be read by many advanced users plus most core developers.
I would prefer if the list does not disappear.
Should we start encouraging folks to post all GeoServer questions onto StackOverflow instead of this mailing list?
I suspect there are advantages doing so.
Klaus Nji
Software Engineering
Honeywell Global Tracking
400 Maple Groove,
Ottawa, ON, K2V 1B8
613-591-6040 x1005
Subversion Kills Productivity. Get off Subversion & Make the Move to Perforce.
With Perforce, you get hassle-free workflows. Merge that actually works.
Faster operations. Version large binaries. Built-in WAN optimization and the
freedom to use Git, Perforce or both. Make the move to Perforce. http://pubads.g.doubleclick.net/gampad/clk?id=122218951&iu=/4140/ostg.clktrk
Klaus Nji
400 Maple Groove,
Ottawa, ON, K2V 1B8
613-591-6040 x1005
Personally I just assume that StackExchange is for people who don’t want to go to the trouble of signing up to the mailing list. That’s fine, I ask Python questions there rather than on a Python list/forum for instance. But I ask GeoServer questions here and QGIS ones on the qgis list.
StackExchange is good as a low barrier for entry, but most people who do GeoServer stuff and have lots of questions will probably end up gravitating here in the longer term I suspect.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Klaus Nji
400 Maple Groove,
Ottawa, ON, K2V 1B8
613-591-6040 x1005
