On Thu, Sep 24, 2015 at 2:21 PM, Henley, Amanda Clarke <
amanda.henley@anonymised.com> wrote:
Dear List,
I have some pre-tiled maps I would like to use to seed geowebcache. I
have a lot of these maps and they are quite large so I'd rather not have to
re-tile them.
Does anyone have suggestions or documentation they could share? I'm still
fairly new to GeoServer.
As far as I know there is no support for pre-tiled pyramids... supporting
them would not be that difficult though
(assuming some proficiency in java programming and tiling protocols), one
has to create a new set of classes
to read them and properly associate their indexes, similar to what has been
done for the arcgis compact cache support:
https://github.com/GeoWebCache/geowebcache/tree/master/geowebcache/arcgiscache
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
