On Thu, Oct 9, 2014 at 11:02 AM, Tom Chadwin <tom.chadwin@anonymised.com>
wrote:
Is it possible to allow certain layers to be requested only when other
layers
are requested with it?
In general terms, that would break the WMS contract, which allows any
combination of the exposed layers.
Well, of course unless you do not expose the layer in question (make it non
advertised),
and eventually lump it into opaque layer groups... at this point the
clients will not see it, but it will
still be available as part of the layer groups
If you don't mind me asking, why do you need the layer to only show up
along with other layers?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
