[Geoserver-users] primary key
Is it normal that a primary key in postgres is no more accessible with geoserver (and by getFeatureInfo through ftl) by its name ? Has a column a special name when it becomes a PK ?
Laurent
Yes, by default primary keys are not made available via normal attributes, it shows up as the feature id of the feature. In a getFeatureInfo template it should be available via "feature.fid".
-Justin
laurent pierrre wrote:
Laurent
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference Don't miss this year's exciting event. There's still time to save $100. Use priority code J8TL2D2. http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Geoserver-users mailing list
!DSPAM:4007,4807455c140841012714783!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Thanks, I was trying to get it by 'feature_id' instead of 'fid'.
-Justin
Laurent
Justin Deoliveira
