[Geoserver-users] Primary keys and geometry in Oracle
Hi List,
When I start GeoServer (2.3-RC1), the first time I go to the layer list, in the console I see the below three lines for many of the layers.
05 Mar 11:26:03 WARN [org.geotools.jdbc] - Failure occurred while looking up the primary key with finder: org.geotools.jdbc.HeuristicPrimaryKeyFinder@anonymised.com
05 Mar 11:26:03 WARN [org.geotools.jdbc] - No primary key or unique index found for BOUNDARY_SUBREGION.
05 Mar 11:26:06 WARN [org.geotools.jdbc] - Unrecognized geometry type DEFAULT falling back on generic ‘GEOMETRY’
These are all Oracle Layers. They have an non-nullable unique-value column that has an index.
Being WARN level events I figured I should try and find out what they’re on about but googling doesn’t find much.
Can anyone advise? It all seems to work so it can probably be ignored, but…
So my questions:
— What does GeoServer need the primary key for?
— What happens if it can’t find it?
— What does “Unrecognized geometry type DEFAULT falling back on generic ‘GEOMETRY’” mean? My geometry is all in sdo_geometry type columns.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
