I need the functionality of “ print to pdf” using Geoserver and GeoExt.
I have added libraries but when I click “createPDF” it says:
Error while generating PDF:
org.mapfish.print.InvalidValueException: url has an invalid value: http://geoserver.org/download/attachments/10158143/pbGS-Bttn228x68.png
at org.mapfish.print.PDFUtils.createImage(PDFUtils.java:385)
at org.mapfish.print.PDFUtils.createImageChunk(PDFUtils.java:376)
at org.mapfish.print.config.layout.ImageBlock.render(ImageBlock.java:60)
at org.mapfish.print.PDFUtils.createCell(PDFUtils.java:345)
at org.mapfish.print.PDFUtils.buildTable(PDFUtils.java:330)
at org.mapfish.print.config.layout.ColumnsBlock.render(ColumnsBlock.java:66)
can you please help me .
Thanks
Satya
Hi Satya,
unfortunately your default yaml template for printing is pointing to an online image that doesn’t exist anymore, and that makes the MapFish print plugin crash.
In newest GeoServer versions (from 2.6) this should be fixed. If you want to fix the version you are using, you need to change the config.yaml file you will find in your geoserver data_dir printing subfolder. Look for the url of the failing image and replace it with another one (or remove the image block alltogether).
Mauro
2015-01-20 12:49 GMT+01:00 Satya Bhargavi <sbommaraju@anonymised.com>:
Thanks
Satya
New Year. New Location. New Benefits. New Data Center in Ashburn, VA.
GigeNET is offering a free month of service with a new server in Ashburn.
Choose from 2 high performing configs, both with 100TB of bandwidth.
Higher redundancy.Lower latency.Increased capacity.Completely compliant.
http://p.sf.net/sfu/gigenet
Geoserver-users mailing list
