Hi Mauro,
Thanks for your help.
Sorry for troubling you again.
I have changed as you said, but no luck.
I have given image url which is existing.
Is that the way? Or can you please suggest.
Thanks
Satya
-----Original Message-----
From: geoserver-users-request@lists.sourceforge.net
[mailto:geoserver-users-request@lists.sourceforge.net]
Sent: Tuesday, January 20, 2015 10:36 PM
Subject: Geoserver-users Digest, Vol 104, Issue 30
Send Geoserver-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
geoserver-users-owner@lists.sourceforge.net
When replying, please edit your Subject line so it is more specific than
"Re: Contents of Geoserver-users digest..."
Today's Topics:
1. Re: Print in geoserver (Mauro Bartolomeoli)
2. Geoserver - Geowebcache Max Cache Level - Need Urgent Help!
(gavin.montgomery)
3. Re: jp2 images will not load (Daniele Romagnoli)
Message: 1
Date: Tue, 20 Jan 2015 13:34:40 +0100
From: Mauro Bartolomeoli <maurobartolomeoli@anonymised.com>
Subject: Re: [Geoserver-users] Print in geoserver
To: Satya Bhargavi <sbommaraju@anonymised.com>
Cc: GeoServer Mailing List List
<geoserver-users@lists.sourceforge.net>
Message-ID:
<CADQU8v1ee9VcO+ZnavW8=yYkCF85vrRiWPKX5O5TLiQ+k0_DwA@anonymised.com>
Content-Type: text/plain; charset="utf-8"
Hi Satya,
unfortunately your default yaml template for printing is pointing to an
online image that doesn't exist anymore, and that makes the MapFish print
plugin crash.
In newest GeoServer versions (from 2.6) this should be fixed. If you want to
fix the version you are using, you need to change the config.yaml file you
will find in your geoserver data_dir printing subfolder. Look for the url of
the failing image and replace it with another one (or remove the image block
alltogether).
Mauro
2015-01-20 12:49 GMT+01:00 Satya Bhargavi <sbommaraju@anonymised.com>:
I need the functionality of ? print to pdf? using Geoserver and GeoExt.
I have added libraries but when I click ?createPDF? it says:
Error while generating PDF:
org.mapfish.print.InvalidValueException: url has an invalid value:
http://geoserver.org/download/attachments/10158143/pbGS-Bttn228x68.pngat org.mapfish.print.PDFUtils.createImage(PDFUtils.java:385)
at
org.mapfish.print.PDFUtils.createImageChunk(PDFUtils.java:376)at
org.mapfish.print.config.layout.ImageBlock.render(ImageBlock.java:60)at org.mapfish.print.PDFUtils.createCell(PDFUtils.java:345)
at org.mapfish.print.PDFUtils.buildTable(PDFUtils.java:330)
at
org.mapfish.print.config.layout.ColumnsBlock.render(ColumnsBlock.java:
66)at org.mapfish.print.PDFUtils.createCell(PDFUtils.java:345)
can you please help me .
Thanks
Satya
-------- New Year. New Location. New Benefits. New Data Center in
Ashburn, VA.
GigeNET is offering a free month of service with a new server in Ashburn.
Choose from 2 high performing configs, both with 100TB of bandwidth.
Higher redundancy.Lower latency.Increased capacity.Completely compliant.
http://p.sf.net/sfu/gigenet
Message: 2
Date: Tue, 20 Jan 2015 08:49:36 -0800 (PST)
From: "gavin.montgomery" <gavin.montgomery@anonymised.com>
Subject: [Geoserver-users] Geoserver - Geowebcache Max Cache Level -
Need Urgent Help!
Message-ID: <1421772576482-5182637.post@anonymised.com>
Content-Type: text/plain; charset=us-ascii
Hi all
We are wanting to display image cache for the entire of England to a level
of 1:3000 (level 10 in our gridset). Beyond that we want to call upon the
standard WMS service, feeding dynamically from the database/file store. The
Layer is being published to level 19.
In Geoserver 2.4.0 any layer that has a "Cached Zoom Level" set to a
particular level (i.e level 10) will dynamically render a WMS service beyond
that level. In geoserver 2.6.0 this no longer happens and we receive an
error from geowebcache:
400: Null (network response in chrome - 400:Bad Request)
I understand that this is beyond the level of cache available but why is
geowebcache no longer going directly to the Layer WMS like before? Is it
possible an error in the geowebcache.xml could cause this?
FYI: I have tried this test on the Geoserver sample layers, as well as my
own to highlight the fact that this is not an independent issue.
I am under a really tight schedule here and need to know if this is a user
error or simply something that is no longer available in geoserver.
Many thanks in advance - appreciate any response
Happy to answer further questions - this question was rather rushed!
<http://osgeo-org.1560.x6.nabble.com/file/n5182637/level_10.png>
<http://osgeo-org.1560.x6.nabble.com/file/n5182637/level_11.png>
<http://osgeo-org.1560.x6.nabble.com/file/n5182637/level_11_response.png>
View this message in context:
http://osgeo-org.1560.x6.nabble.com/Geoserver-Geowebcache-Max-Cache-Level-Ne
ed-Urgent-Help-tp5182637.html
Message: 3
Date: Tue, 20 Jan 2015 18:04:51 +0100
From: Daniele Romagnoli <daniele.romagnoli@anonymised.com>
Subject: Re: [Geoserver-users] jp2 images will not load
To: "Bistrais, Bob" <Bob.Bistrais@anonymised.com>,
"geoserver-users@lists.sourceforge.net"
Message-ID:
<CAJaHrDy9GQT1DDvphGUc_0wnBg=_Ox2LvwUoFXyy6LKQ3ad4qQ@anonymised.com>
Hi Bob,
please keep the mailing list in the loop.
Can you also please share your stderrout log?
Is the one containing info about whether GDAL has been properly loaded or
not.
I have no feedbacks about the URL conversion DEBUG message but I think is a
simple DEBUG message reported by some callback mechanism which is not
reporting anything critical (moreover it isn't related to the GDAL loading
issue)
Hoping some other developers can chime in to provide more info on that if
needed.
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo ? consentito esclusivamente al destinatario del messaggio, per le
finalit? indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalit? diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
On Tue, Jan 20, 2015 at 3:59 PM, Bistrais, Bob <Bob.Bistrais@anonymised.com>
wrote:
Hello Daniele,
Sorry I did not reply sooner, I was out of the office for the past few
days. I have added the GDAL DLL?s to the Path variable. I still get
errors, but I see this at the beginning of the stack trace. This
seems to indicate that GeoSever is not able to convert a URL? Here is
the beginning of the error message, I have attached the complete message.Thank you again,
Bob
2015-01-20 09:50:29,311 TRACE [org.geoserver.ows.OWSHandlerMapping] -
No handler mapping found for [/web/]2015-01-20 09:50:29,311 TRACE [org.geoserver.ows.OWSHandlerMapping] -
No handler mapping found for [/web/]2015-01-20 09:50:29,312 DEBUG [org.geoserver] - Thread 12 locking in
mode WRITE2015-01-20 09:50:29,312 DEBUG [org.geoserver] - Thread 12 got the lock
in mode WRITE2015-01-20 09:50:29,323 DEBUG [org.geoserver.web] - cannot convert url:
jar:file:/C:/Program%20Files%20(x86)/Boundless/OpenGeo/jetty/webapps/g
eoserver/WEB-INF/lib/gs-web-core-2.6-SNAPSHOT.jar!/org/geoserver/web/c
ss/blueprint/screen.css to file (URI is not hierarchical), falling
back to the inputstream for polling2015-01-20 09:50:29,324 DEBUG [org.geoserver.web] - cannot convert url:
ss/blueprint/print.css to file (URI is not hierarchical), falling back
to the inputstream for polling2015-01-20 09:50:29,325 DEBUG [org.geoserver.web] - cannot convert url:
ss/geoserver.css to file (URI is not hierarchical), falling back to
the inputstream for polling*From:* dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] *On
Behalf Of *Daniele Romagnoli
*Sent:* Friday, January 16, 2015 3:29 AM
*To:* Bistrais, Bob
*Subject:* Re: [Geoserver-users] jp2 images will not loadHi Bob,
ah ok. I was thinking you was using Tomcat.
You are using Jetty instead.
from your stderrout file, I see that:
* Jan 15, 2015 11:36:12 AM
it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL WARNING:
Failed to load the GDAL native libs. This is not a problem unless you
need to use the GDAL plugins: they won't be enabled.
java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path *Which states that the GDAL libraries aren't successfully loaded/found.
I'm not familiar with Jetty so I don't know if it needs any specific
configuration or settings.Anyway, at this point I would try adding GDAL_DRIVER_PATH (as
suggested
before) to the System environment variables (I was thinking you did
this in some initialization script, but I don't know how things work with
Jetty).
As well as adding the GDAL DLLs folder to the main PATH environment
variable of the system.Please, let me know.
Daniele
http://goo.gl/NWWaa2 for more information.Ing. Daniele Romagnoli
Senior Software EngineerGeoSolutions S.A.S.
fax: +39 0584 1660272http://www.geo-solutions.it
http://twitter.com/geosolutions_it-------------------------------------------------------
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo ? consentito esclusivamente al destinatario del
messaggio, per le finalit? indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalit?
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Thu, Jan 15, 2015 at 7:00 PM, Bistrais, Bob
wrote:Hi Daniele,
Here are logs from GeoServer. I am looking for Catalina log, but I?m
not finding it. Where would I find this?Thank you very much for helping me.
Bob
*Sent:* Thursday, January 15, 2015 11:43 AM
*To:* Bistrais, Bob
*Cc:* geoserver-users@lists.sourceforge.net
Could you please send me your geoserver and catalina logs?Cheers,
Daniele==
D.Lgs. 196/2003.
New Year. New Location. New Benefits. New Data Center in Ashburn, VA.
End of Geoserver-users Digest, Vol 104, Issue 30
