[Geoserver-users] Print module
Is the GeoServer printing plugin using MapFish version 1.2 in GeoServer version 2.6 and above because I can’t find how to get it to increase the read time for big layers.
When reading aerial photography the MapFish component is logging a Read Time Out error after 30 seconds even if I set the connectionTimeout option in the YMAL and also configure both control flow and the WMS settings to 90 seconds.
Best Regards,
Paul Wittle
GIS Developer
Ext: 710 8473
Tel: 01305 228473
Hi Paul,
we use MapFish 2.1 in GeoServer 2.6 and above. The option you need for read timeouts is probably socketTimeout. Did you try with that one?
Mauro Bartolomeoli
2016-04-19 15:44 GMT+02:00 Paul Wittle <P.Wittle@anonymised.com.7193…>:
Best Regards,
Paul Wittle
GIS Developer
Ext: 710 8473
Tel: 01305 228473
“This e-mail is intended for the named addressee(s) only and may contain information about individuals or other sensitive information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this email in error, kindly disregard the content of the message and notify the sender immediately. Please be aware that all email may be subject to recording and/or monitoring in accordance with relevant legislation.”
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z
Geoserver-users mailing list
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via di Montramito 3/A
We have just put that setting into the YAML as follows:
connectionTimeout: 90000
socketTimeout: 180000
brokenUrlPlaceholder: default
The result was that it still completes in around 30 seconds but with missing layers and the following error message:
2016-04-19 17:07:58,309 ERROR [print.PDFUtils] - Server returned an error for http://{host}/aerial/wms?BBOX=367120.90931137616%2C70718.54520964148%2C369092.93715805584%2C72076.73961963497&HEIGHT=3208&WIDTH=4658&TRANSPARENT=true&map_resolution=300&VERSION=1.1.1&FORMAT=image%2Fpng&SERVICE=WMS&format_options=dpi%3A300&LAYERS=aerial%3Avap%2Caerial%3AIR_VAP_INDEX&REQUEST=GetMap&STYLES=%2C&DPI=300&SRS=EPSG%3A27700: Read timed out
A number of these settings marked since v1.2 just don’t seem to work; no error reading the YAML but they don’t have any effect.
Paul
Hi Paul,
Mauro Bartolomeoli
2016-04-19 15:44 GMT+02:00 Paul Wittle <P.Wittle@…7193…>:
Best Regards,
Paul Wittle
GIS Developer
Ext: 710 8473
Tel: 01305 228473
@mauro_bart
Hi Paul, I had a quick look at the code and it seems that you are right: those settings are ignored.
I don’t know if they were supported in 1.2 and deprecated in 2.x.
A patch to the library would be needed to (re)implement them.
Mauro Bartolomeoli
2016-04-19 18:14 GMT+02:00 Paul Wittle <P.Wittle@anonymised.com>:
Paul
From: Mauro Bartolomeoli [mailto:mauro.bartolomeoli@anonymised.com]
Sent: 19 April 2016 15:56
To: Paul Wittle
Subject: Re: [Geoserver-users] Print module
Hi Paul,
Mauro Bartolomeoli
2016-04-19 15:44 GMT+02:00 Paul Wittle <P.Wittle@anonymised.com>:
Best Regards,
Paul Wittle
GIS Developer
Ext: 710 8473
Tel: 01305 228473
@mauro_bart
@mauro_bart
Hi Paul,
We have a standalone MapFish print which isn’t timing out at all at the MapFish end, I have some requests go up to 90seconds. Any timeouts are all at the GeoServer and/or HAProxy end (60 seconds by default). This is both MFP 1.x and 2.x. There is nothing in the config.yaml to configure timeouts.
So I wonder if a stand-alone MFP might be a solution; they’re pretty easy to setup. Timeouts for us are influenced by either the thing doing the serving (GeoServer), or the MFP container (Tomcat).
Jonathan
---- On Tue, 19 Apr 2016 15:55:44 +0100 Mauro Bartolomeolimauro.bartolomeoli@anonymised.com wrote ----
Hi Paul,
Mauro Bartolomeoli
Best Regards,
Paul Wittle
GIS Developer
Ext: 710 8473
Tel: 01305 228473
@mauro_bart
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z_______________________________________________
