Hi List,
This page:
http://docs.geoserver.org/latest/en/user/extensions/printing/index.html
Has a links to a “sample page” where the module can be printed, the URL is:
http://docs.geoserver.org/latest/en/user/_downloads/print-example.html
However this page doesn’t seem to actually do anything - there’s no map or anything. It seems that the GeoExt stuff has moved from the URL it’s expecting it to be at.
There are instances of most of the javascript libraries on cloudflare, i.e.:
http://cdnjs.cloudflare.com/ajax/libs/geoext/1.1/script/GeoExt.js
Jonathan
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Hi Jonathan,
we are aware of the issue, there is already a JIRA for this: https://jira.codehaus.org/browse/GEOS-6566
We are thinking of the best way to replace that page, probably by a link to the local print demo page, or something similar.
Thanks
Mauro
2014-08-06 12:48 GMT+02:00 Jonathan Moules <jonathanmoules@anonymised.com>:
Hi List,
This page:
Jonathan
Infragistics Professional
Build stunning WinForms apps today!
Reboot your WinForms applications with our WinForms controls.
Build a bridge from your legacy apps to the future.
http://pubads.g.doubleclick.net/gampad/clk?id=153845071&iu=/4140/ostg.clktrk
Geoserver-users mailing list
