[Geoserver-users] Problem 2.9 with view Oracle editable with trigger
In Geoserver 2.8 we didn’t have problem with View editable with trigger in Oracle, but we upgrade to 2.9 and we receive this error when we edit through WFST:
Caused by: java.io.IOException: Error inserting features
at org.geotools.jdbc.JDBCDataStore.insert(JDBCDataStore.java:1697)
at org.geotools.jdbc.JDBCInsertFeatureWriter.flush(JDBCInsertFeatureWriter.java:125)
at org.geotools.jdbc.JDBCInsertFeatureWriter.write(JDBCInsertFeatureWriter.java:97)
at org.geotools.data.InProcessLockingManager$1.write(InProcessLockingManager.java:337)
at org.geotools.data.store.ContentFeatureStore.addFeature(ContentFeatureStore.java:308)
at org.geotools.data.store.ContentFeatureStore.addFeatures(ContentFeatureStore.java:259)
at org.vfny.geoserver.global.GeoServerFeatureStore.addFeatures(GeoServerFeatureStore.java:80)
at org.geoserver.wfs.InsertElementHandler.execute(InsertElementHandler.java:189)
… 108 more
Caused by: java.sql.BatchUpdateException: ORA-22816: unsupported feature with RETURNING clause
at oracle.jdbc.driver.OraclePreparedStatement.executeBatch(OraclePreparedStatement.java:10296)
at oracle.jdbc.driver.OracleStatementWrapper.executeBatch(OracleStatementWrapper.java:216)
at org.apache.commons.dbcp.DelegatingStatement.executeBatch(DelegatingStatement.java:297)
at org.geotools.jdbc.JDBCDataStore.insertPS(JDBCDataStore.java:1762)
at org.geotools.jdbc.JDBCDataStore.insert(JDBCDataStore.java:1683)
… 115 more
any help??
thanks
This page [1] should help you to find the reason of the error. The usage of RETURNING is quite new in GeoTools and has been introduced for performance reasons.
[1] http://psoug.org/oraerror/ORA-22816.htm
On Mon, Sep 12, 2016 at 8:40 PM, Cristian Olguín Avila <cristianolguin@anonymised.com> wrote:
… 108 more
… 115 more
any help??
thanks
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. http://sdm.link/zohodev2dev
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Hi Patrick,
not sure if you have noticed, that performance work is also the likely cause for a regression we are
experiencing against sql server:
https://osgeo-org.atlassian.net/browse/GEOS-7681
On Tue, Sep 20, 2016 at 2:34 PM, Patrick Valsecchi <patrick.valsecchi@anonymised.com> wrote:
… 108 more
… 115 more
any help??
thanks
Geoserver-users@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
