Thanks for having reported that.
I’m keeping the list in the loop so in case anyone in the future has similar issue with GeoServer used in docker, he can know how to deal with that.
On Mon, Jul 6, 2015 at 12:39 PM, Attakorn Poonkesorn <attakornpks@anonymised.com3…> wrote:
Hello, I would like to say that I got this working, it’s because I used docker to run geoserver and the variables wasn’t exported properly when it run the geoserver startup script. I just fixed this by manually run the startup script after I confirmed that environments are exported in docker container. Thanks for your answer.
CartoonMed
On Fri, Jul 3, 2015 at 7:45 PM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Your logs are reporting that the native library loading failed:
Jul 03, 2015 11:08:34 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won’t be enabled.
java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
That explains why you are unable to see GDAL coverageStores.
I would suggest to check again the documentation reported here:
http://docs.geoserver.org/stable/en/user/data/raster/gdal.html
And take a look to the second warning and first note:
If you are on Linux, be sure to set the LD_LIBRARY_PATH environment variable to refer to the folder where the SOs are extracted.
The native libraries contains the GDAL gdalinfo utility which can be used to test whether or not the libs are corrupted. This can be done by browsing to the directory where the libs have been extracted and performing a gdalinfo command with the formats options that shows all the formats supported. Moreover the package contains also a Java versions of the gdalinfo utility to check also the Java bindings correct functioning (you can see a .bat script for Windows and .sh for Linux).
I would make sure that the Environment variable is properly configured as well as the java gdalinfo command execution doesn’t report any error.
Please, let us know.
Best Regards,
Daniele
On Fri, Jul 3, 2015 at 1:54 PM, Attakorn Poonkesorn <attakornpks@anonymised.com.7133…> wrote:
I have attached the log file in email, please have a look
Thank you,
CartoonMed
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
On Fri, Jul 3, 2015 at 3:19 PM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hi again,
I’m keeping the mailing list in the loop so that other people can provide additional feedbacks or share solutions in case they already had same issue.
Do you have any chance to raise the logging level (maybe VERBOSE) and share the logs starting from GeoServer startup?
Wondering if we can catch any message reported by the GridFormatFinder or other classes stating that it can’t load the GDAL format.
Daniele
On Fri, Jul 3, 2015 at 9:30 AM, Attakorn Poonkesorn <attakornpks@anonymised.com> wrote:
“are you saying that you go to “add new store” in GeoServer GUI and you don’t see additional stores beside standard GeoTIFF and similar?”
This is the right one
“Could you do an “ls gdal” from the geoserver/WEB-INF/lib folder?”
Yes, I can. And it return these lines
gs-gdal-2.7.1.jar imageio-ext-gdaldted-1.1.10.jar imageio-ext-gdalenvihdr-1.1.10.jar imageio-ext-gdalkakadujp2-1.1.10.jar imageio-ext-gdalrpftoc-1.1.10.jar
gt-imageio-ext-gdal-13.1.jar imageio-ext-gdalecw-1.1.10.jar imageio-ext-gdalerdasimg-1.1.10.jar imageio-ext-gdalmrsid-1.1.10.jar
imageio-ext-gdalarcbinarygrid-1.1.10.jar imageio-ext-gdalecwjp2-1.1.10.jar imageio-ext-gdalframework-1.1.10.jar imageio-ext-gdalmrsidjp2-1.1.10.jar
imageio-ext-gdal-bindings-1.9.2.jar imageio-ext-gdalehdr-1.1.10.jar imageio-ext-gdalidrisi-1.1.10.jar imageio-ext-gdalnitf-1.1.10.jar
For more information. I can add other extension just fine, ImageMosaic and ImagePyramid shows up normally at Geoserver GUI when I try to add new store
Best regards,
CartoonMed
On Jul 2, 2015 10:00 PM, “Daniele Romagnoli” <daniele.romagnoli@anonymised.com> wrote:
Or are you saying that you can add a new GDAL store but you don’t see anything when doing a layer preview instead?
Just making sure that all the required jars are available. It seems to me that the imageio-ext low level part is available (the one notifying the message you have reported) but the GeoTools format isn’t available…
Best regards,
Daniele
On Thu, Jul 2, 2015 at 4:22 PM, Attakorn Poonkesorn <attakornpks@anonymised.com> wrote:
Hello Members,
I have problem about installing GDAL extension in geoserver 2.7.1 on Ubuntu 14.04 LTS
I have install GDAL extension as instructed at http://docs.geoserver.org/stable/en/user/data/raster/gdal.html
I have exported GDAL_DATA to the right path, LD_LIBRARY_PATH is set to native library that I have downloaded as instructed and jar files is already in WEB-INF/lib
When I start geoserver it says GDAL successfully loaded version 1.9.2 or something like that
But after everything is done nothing show up when I try to add new stores
Thank you in advance.
Don’t Limit Your Business. Reach for the Cloud.
GigeNET’s Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
Geoserver-users mailing list
