[Geoserver-users] problem accessing datastores with user-defined namespace
hello all,
i'm trying to use the latest GeoServer 1.6.1, and am unable to access
my DataStores if/when they use my own (user-defined) namespace. for
example the following datastore entry in the catalog.xml:
    <datastore id = "xxx" enabled = "true" namespace = "integeo" >
      <connectionParams >
        <parameter name = "namespace" value = "integeo" />
      </connectionParams>
    </datastore>
causes the following exception to be thrown when issuing a WMS
DescribeLayer request for it (from my code which uses GeoTools 2.4.1):
2008-03-04 14:09:25,670 WARN [geoserver.ows] -
java.lang.RuntimeException: Parsing failed for TypeName: java.lang.IllegalArgumentException: prefix integeo is not bound to a
namespace
  at org.geotools.xml.impl.ParseExecutor.visit(ParseExecutor.java:142)
  at org.geotools.xml.impl.BindingWalker$BindingExecutionChain.execute(BindingWalker.java:197)
  at org.geotools.xml.impl.BindingWalker.walk(BindingWalker.java:163)
  at org.geotools.xml.impl.ElementHandlerImpl.endElement(ElementHandlerImpl.java:222)
  at org.geotools.xml.impl.ParserHandler.endElement(ParserHandler.java:499)
  at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
  at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknown Source)
  at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
  at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
  at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
  at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
  at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
  at org.geotools.xml.Parser.parse(Parser.java:185)
  at org.geotools.xml.Parser.parse(Parser.java:164)
  at org.geoserver.wfs.xml.v1_0_0.WfsXmlReader.read(WfsXmlReader.java:60)
  at org.geoserver.ows.Dispatcher.parseRequestXML(Dispatcher.java:1058)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:375)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:185)
  at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
  at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:357)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:459)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1054)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1045)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:69)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
  at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
  at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
  at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
  at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
  at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:358)
  at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:231)
  at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:629)
  at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:453)
  at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:149)
  at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:123)
  at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
  at org.mortbay.jetty.Server.handle(Server.java:303)
  at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:452)
  at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:735)
  at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:636)
  at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:203)
  at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:349)
  at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:320)
  at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:475)
Caused by: java.lang.IllegalArgumentException: prefix integeo is not bound to a namespace
  at javax.xml.bind.DatatypeConverterImpl._parseQName(DatatypeConverterImpl.java:299)
  at javax.xml.bind.DatatypeConverterImpl.parseQName(DatatypeConverterImpl.java:255)
  at javax.xml.bind.DatatypeConverter.parseQName(DatatypeConverter.java:268)
  at org.geotools.xs.bindings.XSQNameBinding.parse(XSQNameBinding.java:109)
  at org.geotools.xml.impl.ParseExecutor.visit(ParseExecutor.java:128)
  ... 64 more
the prefix _is_ defined in catalog.xml:
  <namespaces >
    <namespace default = "true" prefix = "integeo" uri = "http://www.integeo.com" />
    <namespace prefix = "cite" uri = "http://www.opengeospatial.net/cite&quot; />
furthermore, issuing a similar request from the GeoServer Demo pages
works w/o any exceptions.
finally changing the namespace to topp (i haven't tried any other) works ok.
is it a mis-configuration on my part, or should i enter this in JIRA?
btw. i had the same behaviour with 1.6.0 as well.
TIA + cheers;
rsn
Raif S. Naffah ha scritto:
hello all,
      <connectionParams >
      </connectionParams>
    </datastore>
2008-03-04 14:09:25,670 WARN [geoserver.ows] - java.lang.RuntimeException: Parsing failed for TypeName: java.lang.IllegalArgumentException: prefix integeo is not bound to a namespace
  ... 64 more
  <namespaces >
This is looks like being:
http://jira.codehaus.org/browse/GEOS-1558
which should have been fixed, and is similar to:
http://jira.codehaus.org/browse/GEOS-1756
http://jira.codehaus.org/browse/GEOS-1773
I guess some more work is needed to make non default namespaces to
actually work again. Raif, any chance you can set integeo to be
the default namespace for the moment?
Hmm... I am having trouble replicating this one. Tim is having a similar problem with his versioning demo. I will dig deeper.
hello all,
      <connectionParams >
      </connectionParams>
    </datastore>
  ... 64 more
  <namespaces >
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
!DSPAM:4007,47cd09e7215071637810514!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
hello Andrea,
thanks for your quick reply!
as i mentioned earlier, tried setting my own namespace as the default
one, and tried sending the request with no namespace-colon prefix but
that didn't work either.
this, as you mention looks indeed similar to GEOS-1773, with even the
same line number (142) of the visit() method of the
org.geotools.xml.impl.ParseExecutor class!
btw. i'm using Sun's JDK 1.6.0_04.
> hello all,
> access my DataStores if/when they use my own (user-defined)
> namespace. for example the following datastore entry in the
> catalog.xml:
> <connectionParams >
> </connectionParams>
> </datastore>
> 2.4.1):
> a namespace
> at
> at
>indingWalker.java:197) at
> org.geotools.xml.impl.BindingWalker.walk(BindingWalker.java:163) at
>mpl.java:222) at
>99) at
> Source) at
>own Source) at
>ntDispatcher.dispatch(Unknown Source) at
>Unknown Source) at
> Source) at org.apache.xerces.parsers.XMLParser.parse(Unknown
> Source) at
> at
>) at
> at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:375) at
>185) at
>t(AbstractController.java:139) at
>handle(SimpleControllerHandlerAdapter.java:44) at
>cherServlet.java:684) at
>herServlet.java:625) at
>meworkServlet.java:392) at
>rvlet.java:357) at
> javax.servlet.http.HttpServlet.service(HttpServlet.java:709) at
> javax.servlet.http.HttpServlet.service(HttpServlet.java:802) at
>59) at
>etHandler.java:1054) at
>haracterEncodingFilter.java:108) at
>etHandler.java:1045) at
> at
> org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41) at
>(FilterChainProxy.java:264) at
>lterSecurityInterceptor.java:107) at
>FilterSecurityInterceptor.java:72) at
>(FilterChainProxy.java:274) at
>ranslationFilter.java:110) at
>ilter(AnonymousProcessingFilter.java:125) at
>ProcessingFilter.java:178) at
>ter(HttpSessionContextIntegrationFilter.java:229) at
>ava:148) at
>.java:98) at
>:358) at
>:231) at
>:629) at
>3) at
>ndlerCollection.java:149) at
>n.java:123) at
>:141) at org.mortbay.jetty.Server.handle(Server.java:303)
> at
>452) at
>ion.java:735) at
> org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:636) at
> org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:203) at
> org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:349) at
>java:320) at
>ol.java:475) Caused by: java.lang.IllegalArgumentException: prefix
> integeo is not bound to a namespace at
>mpl.java:299) at
>pl.java:255) at
>268) at
>09) at
> ... 64 more
> <namespaces >
> "http://www.integeo.com" /> <namespace prefix = "cite" uri =
> "http://www.opengeospatial.net/cite&quot; /> ...
> pages works w/o any exceptions.
> works ok.
> JIRA?
TIA + cheers;
rsn
hello all,
as a follow-up to my original post, here are some more findings i
discovered related to the above issue:
* editing the catalog.xml file to use a known (not user-defined)
namespace as the default, solves the WMS/DescribeLayer issue but an
exception is thrown later when trying to use a WFS DataStore over those
Features whose name is used w/o a namespace prefix.
* editing the catalog.xml file and adding a _dummy_ namespace entry and
specifying it as the default (e.g.
  <namespaces>
    <namespace default = "true" prefix = "xxx" uri = "http://www.xxx"/>
) seems to be a workaround which also allows Clients software and
configurations already using fully qualified layer/feature names with
user-defined namespaces to continue working unchanged with GeoServer.
On Wednesday 05 March 2008 08:57:55 am Raif S. Naffah wrote:
hello Andrea,
> > hello all,
> > catalog.xml:
> > > <connectionParams >
> > </connectionParams>
> > </datastore>
> > 2.4.1):
> > to a namespace
> > at
> > at
> >(B indingWalker.java:197) at
> > at
> >rI mpl.java:222) at
> >:4 99) at
> > Source) at
> >kn own Source) at
> >te ntDispatcher.dispatch(Unknown Source) at
> >t( Unknown Source) at
> > Source) at
> > Source) at
> > at
> >60 ) at
> >) at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:375) at
> >a: 185) at
> >es t(AbstractController.java:139) at
> >r. handle(SimpleControllerHandlerAdapter.java:44) at
> >at cherServlet.java:684) at
> >tc herServlet.java:625) at
> >ra meworkServlet.java:392) at
> >Se rvlet.java:357) at
> >:4 59) at
> >vl etHandler.java:1054) at
> >tC haracterEncodingFilter.java:108) at
> >vl etHandler.java:1045) at
> >9) at
> >er (FilterChainProxy.java:264) at
> >Fi lterSecurityInterceptor.java:107) at
> >r( FilterSecurityInterceptor.java:72) at
> >er (FilterChainProxy.java:274) at
> >nT ranslationFilter.java:110) at
> >oF ilter(AnonymousProcessingFilter.java:125) at
> >ic ProcessingFilter.java:178) at
> >il ter(HttpSessionContextIntegrationFilter.java:229) at
> >.j ava:148) at
> >xy .java:98) at
> >va
> >:358) at
> >va
> >:231) at
> >va
> >:629) at
> >45 3) at
> >Ha ndlerCollection.java:149) at
> >io n.java:123) at
> >va
> > at
> >a: 452) at
> >ct ion.java:735) at
> > at
> > at
> >t. java:320) at
> >Po ol.java:475) Caused by: java.lang.IllegalArgumentException:
> > prefix integeo is not bound to a namespace at
> >rI mpl.java:299) at
> >Im pl.java:255) at
> >a: 268) at
> >:1 09) at
> > ... 64 more
> > <namespaces >
> > other) works ok.
> > JIRA?
> Cheers
> Andrea
TIA + cheers;
rsn
cheers;
rsn
