[Geoserver-users] Problem call bbox from within a filter: get java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 error
I am trying to move the bbox parameter to the filter parameter because I need to also query against an attribute. I have been able to successfully queries the attribute but before I combine I need to get the bbox within a filter to work. I have listed the url encoded string (at the bottom) that has the bbox within a filter which give me the following error:
The filter without the encoding is the following:
filter = ‘(ogc:Filterogc:BBOXogc:PropertyNamethe_geom</ogc:PropertyName><gml:Box srsName=“http://www.opengis.net/gml/srs/epsg.xml#4326”>gml:coordinates-117.25,32.70 -117.00,32.80</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter>)’
What have I done incorrectly?
http%3A//localhost%3A8080/geoserver/wfs%3FSERVICE%3DWFS%26VERSION%3D1.0.0%26REQUEST%3DGetFeature%26TYPENAME%3Dvector%253Agv_collaboration_points%252Cvector%253Agv_collaboration_lines%252Cvector%253Agv_collaboration_polygons%252Cvector%253Apush_pins%26MAXFEATURES%3D20%26filter%3D%28%253Cogc%253AFilter%253E%253Cogc%253ABBOX%253E%253Cogc%253APropertyName%253Ethe_geom%253C%252Fogc%253APropertyName%253E%253Cgml%253ABox%2520srsName%253D%2522http%253A%252F%252Fwww.opengis.net%252Fgml%252Fsrs%252Fepsg.xml%25234326%2522%253E%253Cgml%253Acoordinates%253E-117.25%252C32.70%2520-117.00%252C32.80%253C%252Fgml%253Acoordinates%253E%253C%252Fgml%253ABox%253E%253C%252Fogc%253ABBOX%253E%253C%252Fogc%253AFilter%253E%29
John J. Mitchell
John Mitchell ha scritto:
filter = '(<ogc:Filter><ogc:BBOX><ogc:PropertyName>the_geom</ogc:PropertyName><gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#4326&quot;&gt;&lt;gml:coordinates&gt;\-117\.25,32\.70 -117.00,32.80</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter>)'
I don't know... I've tried the above filter in FF against 1.7.0-rc1 and
it worked fine:
http://localhost:8080/geoserver/wfs?request=GetFeature&version=1.1.0&typeName=topp:states&propertyName=STATE_NAME,PERSONS&(<ogc:Filter><ogc:BBOX><ogc:PropertyName>the_geom</ogc:PropertyName><gml:Box%20srsName="http://www.opengis.net/gml/srs/epsg.xml#4326"><gml:coordinates>-117.25,32.70%20-117.00,32.80</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter>)
Hi John,
Is it possible you could include the entire stack trace (from the console or server log). That should give us more info about what exactly is going wrong here.
-Justin
John Mitchell wrote:
http%3A//localhost%3A8080/geoserver/wfs%3FSERVICE%3DWFS%26VERSION%3D1.0.0%26REQUEST%3DGetFeature%26TYPENAME%3Dvector%253Agv_collaboration_points%252Cvector%253Agv_collaboration_lines%252Cvector%253Agv_collaboration_polygons%252Cvector%253Apush_pins%26MAXFEATURES%3D20%26filter%3D%28%253Cogc%253AFilter%253E%253Cogc%253ABBOX%253E%253Cogc%253APropertyName%253Ethe_geom%253C%252Fogc%253APropertyName%253E%253Cgml%253ABox%2520srsName%253D%2522http%253A%252F%252Fwww.opengis.net <http://252Fwww.opengis.net>%252Fgml%252Fsrs%252Fepsg.xml%25234326%2522%253E%253Cgml%253Acoordinates%253E-117.25%252C32.70%2520-117.00%252C32.80%253C%252Fgml%253Acoordinates%253E%253C%252Fgml%253ABox%253E%253C%252Fogc%253ABBOX%253E%253C%252Fogc%253AFilter%253E%29
John J. Mitchell
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Justin Deoliveira
Software Engineer, OpenGeo
http://opengeo.org
