[Geoserver-users] Problem configuring JPEG WorldImages (works with identical PNG)
Have a look at the default data_dir. From data_dir\coverages\img_sample you can find an image “usa.jpeg” which you can publish simply by creating a store and layer. Perhaps the secret is in the file “usa.meta” which has contents:
Layer Name = Map Capture 1111440603125
Origin Longitude = -130.85168
Origin Latitude = 20.7052
Corner Longitude = -62.0054
Corner Latitude = 54.1141
Now we need some developer to tell how to write this .meta file. Obviously a .prj file is needed as well.
-Jukka Rahkonen-
César Martínez Izquierdo wrote:
Thank you very much for all the suggestions. We want to offer our users the option to upload JPGs, but we might consider to re-code the image before sending it to Geoserver. I assume the best option is Geotiff using tiles and overviews.
@Jukka: I have tried several variation, such as renaming the .wld to .jgw, the .jpg to .jpeg, including or excluding the .xml generated by gdal, etc. No one worked.
In any case, I will open a ticket as suggested.
César
On 6 February 2016 at 12:17, Andrea Aime <andrea.aime@…1107…> wrote:
On Fri, Feb 5, 2016 at 6:30 PM, César Martínez Izquierdo <cesar.izq@…84…> wrote:
Caused by: java.util.NoSuchElementException
at com.sun.imageio.plugins.jpeg.ImageTypeIterator.next(JPEGImageReader.java:1722)
at com.sun.imageio.plugins.jpeg.ImageTypeIterator.next(JPEGImageReader.java:1694)
at org.geotools.coverage.grid.io.AbstractGridCoverage2DReader.setLayout(AbstractGridCoverage2DReader.java:1164)
By the looks of this error it seems that the Java own JPEG reader cannot recognize this JPEG variant.
Never seen this error, but I agree with Jukka, serving world files is a recipe for slowness, there
is no inner tiling, every time one has to go, read and un-compress the entire image even if
the area of interest is a small bit.
Anyways, as an alternative to try out, you could install the turbo-jpeg extension:
http://docs.geoserver.org/latest/en/user/extensions/libjpeg-turbo/index.html
It is advertised as an output format, but as far as I know the library also comes as a reader
which might replace the Java built in one. You might give a go at it and see if this
one car read your file.
In any case, I’d open a ticket and attach a sample file that cannot be opened.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
GIS developer
SCOLAB: http://www.scolab.es
