[Geoserver-users] Problem deleting a "Style" from GeoServer
Hi – I’m having a problem deleting a “Style” using the GeoServer administration gui. We have geoserver installed on a server with Apache TomCat, PostGIS, and OpenLayers. When I use the GeoServer administration interface to delete a Style, GeoServer reports that it has deleted it OK but the file still remains on the server in TomCat\WebApps\GeoServer\Data\Styles. I have to manually go in and delete it from there. Is there a configuration setting I’ve missed? How do I correct this?
Mary
I believe it's a bug that we cannot easily solve in 1.7.x
Basically, we could to remove the file when you press submit, but
then you might not end up pressing apply/save, and when apply/save
are pressed, we have no way to tell which style was removed anymore
(because there is nothing keeping track of that).
I believe this issue should not affect GeoServer 2.0, at least there
we have the certainty about what's about to be removed and we should
be able to remove the sld files as well.
Andrea Aime
OpenGeo - http://opengeo.org
Personally I've always thought of this as a feature rather than a bug.
It's nice knowing that even if someone deletes a style I still have
the file on the server. What would also be a nice improvement here is
if when you try to add a style and the file already exists it would
pick up that existing style right away. Currently it fails because it
wants to write the file and it already exists, so you have to go move
the file out of the way and then use its contents to recreate the
style as if it were brand new.
This message brought to you by Speed of Light Beer
When you're approaching infinite mass
It's Speed of Light time!
Agreed, I think that is the real reason this was never done, to avoid permanently deleting data. But the apply save problem is definitely an issue as well.
In 2.0 it should be easy enough to add a flag to the delete that will allow the user to physically delete the underlying SLD file. Feel free to open a jira anyone.
-Justin
Justin Deoliveira
