[Geoserver-users] Problem encountered during GeoBatch startup
I am posting to this list because the GeoBatch User group for some reason does not permit me to post a new topic to it.
I just installed GeoBatch 1.3.0 and ran through the Installation instructions in the documentation. I overrode the configuration to have a separate config directory and separate location for my ‘gb_database.properties’ file.
I am using the default sample “catalog.xml” file located in my GeoBatch config directory and upon startup I get the following error in the geobatch.log file:
The key error below is: “Caused by: com.thoughtworks.xstream.converters.reflection.ObjectAccessException: Cannot construct it.geosolutions.geobatch.configuration.flow.file.FileBasedCatalogConfiguration as it does not have a no-args constructor” and when I look at the GeoBatch source code sure enough the FileBasedCatalogConfiguration class does not have a no-args constructor which I believe is necessary in order for the Spring Framework to instantiate that class.
Any help on this would be appreciated.
–Steve
2014-07-30 17:50:11,330 ERROR ContextLoader:220 - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘globalConfig’ defined in URL [jar:file:/D:/apache-tomcat-7.0.53-8787-geobatch/webapps/geobatch/WEB-INF/lib/gb-dao-xstream-1.3.0.jar!/applicationContext.xml]: Invocation of init method failed; nested exception is java.io.IOException: Unable to load catalog config ‘catalog’ from base dir D:\Data\GeoBatch\config
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1412)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:288)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:190)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:574)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:895)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:425)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:276)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:197)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:47)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4973)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5467)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:632)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1073)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1857)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: Unable to load catalog config ‘catalog’ from base dir D:\Data\GeoBatch\config
at it.geosolutions.geobatch.catalog.dao.file.xstream.XStreamCatalogDAO.find(XStreamCatalogDAO.java:80)
at it.geosolutions.geobatch.catalog.dao.file.xstream.XStreamCatalogDAO.find(XStreamCatalogDAO.java:47)
at it.geosolutions.geobatch.catalog.impl.BasePersistentResource.load(BasePersistentResource.java:85)
at it.geosolutions.geobatch.global.XStreamCatalogLoader.init(XStreamCatalogLoader.java:101)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1536)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1477)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1409)
… 25 more
Caused by: com.thoughtworks.xstream.converters.ConversionException: Cannot construct it.geosolutions.geobatch.configuration.flow.file.FileBasedCatalogConfiguration as it does not have a no-args constructor : Cannot construct it.geosolutions.geobatch.configuration.flow.file.FileBasedCatalogConfiguration as it does not have a no-args constructor
---- Debugging information ----
message : Cannot construct it.geosolutions.geobatch.configuration.flow.file.FileBasedCatalogConfiguration as it does not have a no-args constructor
cause-exception : com.thoughtworks.xstream.converters.reflection.ObjectAccessException
cause-message : Cannot construct it.geosolutions.geobatch.configuration.flow.file.FileBasedCatalogConfiguration as it does not have a no-args constructor
class : it.geosolutions.geobatch.configuration.flow.file.FileBasedCatalogConfiguration
required-type : it.geosolutions.geobatch.configuration.flow.file.FileBasedCatalogConfiguration
path : /CatalogConfiguration
line number : 2
Stephen Brooke (a.k.a. Steve)
Software Engineer III
Ground Systems
MDA
http://www.mda.ca
sbrooke@anonymised.com
Direct phone
+1 604 231 2429
Cell phone
+1 778 839 3274
Switchboard
+1 604 278 3411
FAX
+1 604 231 2757
This e-mail and any attachments are intended solely for the use of the intended recipient(s) and may contain legally privileged, proprietary and/or confidential information. Any use, disclosure, dissemination, distribution or copying of this e-mail and any attachments for any purposes that have not been specifically authorized by the sender is strictly prohibited. If you are not the intended recipient, please immediately notify the sender by reply e-mail and permanently delete all copies and attachments.
The entire content of this e-mail is for “information purposes” only and should not be relied upon by the recipient in any way unless otherwise confirmed in writing by way of letter or facsimile.
Hi Stephen,
this error says that the application couldn’t read the file D:\Data\GeoBatch\config\catalog.xml .
Check if you have the catalog.xml file in that directory and try to change the path using slashes instead of backslashes, like this : D:/Data/GeoBatch/config/catalog.xml
Lorenzo.
2014-07-31 3:03 GMT+02:00 Stephen Brooke <sbrooke@anonymised.com>:
–Steve
… 25 more
line number : 2
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:89)
at com.thoughtworks.xstream.core.AbstractReferenceUnmarshaller.convert(AbstractReferenceUnmarshaller.java:63)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:76)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:60)
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:137)
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:33)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:923)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:909)
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:861)
at it.geosolutions.geobatch.catalog.dao.file.xstream.XStreamCatalogDAO.find(XStreamCatalogDAO.java:70)
… 35 more
at com.thoughtworks.xstream.converters.reflection.PureJavaReflectionProvider.newInstance(PureJavaReflectionProvider.java:71)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.instantiateNewInstance(AbstractReflectionConverter.java:308)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.unmarshal(AbstractReflectionConverter.java:161)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:82)
… 44 more
… 25 more
line number : 2
… 35 more
… 44 more
Ground Systems
MDA
http://www.mda.ca
Direct phone
+1 604 231 2429
Cell phone
+1 778 839 3274
Switchboard
+1 604 278 3411
FAX
+1 604 231 2757
Infragistics Professional
Build stunning WinForms apps today!
Reboot your WinForms applications with our WinForms controls.
Build a bridge from your legacy apps to the future.
http://pubads.g.doubleclick.net/gampad/clk?id=153845071&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Lorenzo Natali
Dott. Ing. Lorenzo Natali
@lorenzonatali
Software Engineer
Via Poggio alle Viti 1187
mob: +39 333 8128928
Hi Lorenzo,
Thanks for your response. I tried what you suggested but I get the same error.
–Steve
Hi Stephen,
Lorenzo.
2014-07-31 3:03 GMT+02:00 Stephen Brooke <sbrooke@…3836…>:
–Steve
… 25 more
line number : 2
… 35 more
… 44 more
… 25 more
line number : 2
… 35 more
… 44 more
Ground Systems
MDA
http://www.mda.ca
sbrooke@…3836…
Direct phone
+1 604 231 2429
Cell phone
+1 778 839 3274
Switchboard
+1 604 278 3411
FAX
+1 604 231 2757
Lorenzo Natali
@lorenzonatali
Software Engineer
It seems you were not a member of the geobatch user group.
You should have received an invitation by the administrator.
Please post this discussion again on the other mailing list.
Lorenzo.
2014-07-31 18:43 GMT+02:00 Stephen Brooke <sbrooke@anonymised.com>:
Hi Lorenzo,
–Steve
From: offtherailz@anonymised.com [mailto:offtherailz@anonymised.com] On Behalf Of Lorenzo Natali
Sent: Thursday, July 31, 2014 5:58 AM
To: Stephen Brooke
Subject: Re: [Geoserver-users] Problem encountered during GeoBatch startup
Hi Stephen,
Lorenzo.
–Steve
… 25 more
line number : 2
… 35 more
… 44 more
… 25 more
line number : 2
… 35 more
… 44 more
Ground Systems
MDA
http://www.mda.ca
Direct phone
+1 604 231 2429
Cell phone
+1 778 839 3274
Switchboard
+1 604 278 3411
FAX
+1 604 231 2757
Lorenzo Natali
@lorenzonatali
Software Engineer
Lorenzo Natali
@lorenzonatali
Software Engineer
