Hi everybody,
I tried to filter the wms query using “cql_filter=…” in the url. It works ok in the browser.
However two issues:
minor: when i call wms/kml_reflect?layers=my:layer&cql_filter=… the resulting kmz is a networklink. in the url of it, the cql_filter has disappeared
major: when i put back the cql_filter in the networklink, i can’t get anything. I checked the logs. It tells me that it cam’t apply styling…
Any idea?
Gersh
error stack:
30 Aug 17:34:42 DEBUG [ geoserver.kml] - Applying rule:
org.geotools.styling.RuleImpl@anonymised.com
30 Aug 17:34:42 DEBUG [geoserver.kml] - Applying symbolizer
org.geotools.styling.PolygonSymbolizerImpl@anonymised.com
30 Aug 17:34:42 WARN [geoserver.kml ] - Failure tranforming feature to
KML:gepolygon.16
java.lang.NullPointerException
at org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.geometryCentroid(KMLVectorTransformer.java :823)
at org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encodePlacemark(KMLVectorTransformer.java:513)
at org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encode (KMLVectorTransformer.java:217)
at org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encode(KMLVectorTransformer.java:191)
at org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encode (KMLVectorTransformer.java:171)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:174)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode (KMLTransformer.java:110)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:702)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java :484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:295)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:128)
at org.geotools.xml.transform.TransformerBase.transform (TransformerBase.java:107)
at org.vfny.geoserver.wms.responses.map.kml.KMZMapProducer.writeTo(KMZMapProducer.java:100)
at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:501)
at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:611)
at org.geoserver.ows.Dispatcher.handleRequestInternal (Dispatcher.java:210)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle (SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java :625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java :269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java :72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java :125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java :229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter (FilterToBeanProxy.java:98)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java :188)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java :215)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:210)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke (ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:870)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket (PoolTcpEndpoint.java:528)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java :685)
at java.lang.Thread.run(Thread.java:619)
