[Geoserver-users] Problem in creating FeatureType for SQL Server 2008 DataStore
I created a SQL Server 2008 datastore, but got a problem when creating
FeatureTypes for it. I downloaed st99_d00.shp, st99_d00.shx, st99_d00.dbf
and then imported data to PostgreSQL and SQL Server 2008 databases
respectively.
When creating a FeatureType by a PostGreSQL datastore, geoServer populated
value to SRS and then Min/Max Long, Min/Max Lat after clicking Generate
button. Then I could see the map in Mini-map preview of the eanbled
FeatureTypes.
When create a FeatureType by a SQL Server datastore, I had to enter values
for SRS, Long, Lat myself. Then I clicked Submit, Apply, Save buttons.
Finally, I viewed the FeatureType. it shown window, background, zoom icon,
but no map. I draged and moved around inside the window several times, it
displayed error
java.lang.RuntimeException: java.lang.RuntimeException: java.io.IOException
java.lang.RuntimeException: java.io.IOException java.io.IOException null No
code "EPSG:0" from authority "European Petroleum Survey Group" found for
object of type "IdentifiedObject".
View this message in context: http://www.nabble.com/Problem-in-creating-FeatureType-for-SQL-Server-2008-DataStore-tp23183460p23183460.html
