Dear sir,
Iam facing problem in deploying GEOSERVER with TJS service…
i followed the steps in the file, attached to this mail…
iam to unable to download the jars files from the following link
https://github.com/thijsbrentjens/geoserver/blob/tjs_2.2.x/binaries/libs-20131219.zip
And while executing the command iam getting following error:
[INFO] Table Joining Service Model(net.opengis.tjs) … SUCCESS [ 3.506 s]
[INFO] TJS XML Support(xsd-tjs) … SUCCESS [ 2.049 s]
[INFO] Geomix TJS Datasource suport(tjs-data) … SUCCESS [ 1.532 s]
[INFO] GeoMIX TJS for Geoserver(tjs-core) … FAILURE [ 3.246 s]
[INFO] GeoMIX TJS for Geoserver UI Module(tjs-web) … SKIPPED
[INFO] Geomix TJS(tjs) … SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10.748 s
[INFO] Finished at: 2014-09-08T13:48:31+05:30
[INFO] Final Memory: 48M/510M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.1:compile (default-compile) on project tjs-core: Compilation failure
Please kindly guide how to deploy geoserver with TJS service…
README.md (3.33 KB)
