[Geoserver-users] Problem installing community schema branch
I am trying to follow the instructions for installing community schema branch
as provided at http://docs.codehaus.org/display/GEOS/Complex+Datastore. I
have been able to execute first step successfully, i.e. installing geotools.
However, when trying to install geoserver source code I get the following
error:
Command executed: mvn install -Dcommunity -DconfigId=community-schema
-DconfigDirectory=../configuration
[INFO]
[ERROR] BUILD ERROR
[INFO]
[INFO] Failed to resolve artifact.
Missing:
1) org.geotools:gt2-fm:jar:2.4-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geotools -DartifactId=gt2-fm
-Dvers
ion=2.4-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file
there:
      mvn deploy:deploy-file -DgroupId=org.geotools -DartifactId=gt2-fm
-Dversio
n=2.4-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url]
-DrepositoryId=[
id]
  Path to dependency:
        1) org.geoserver:wfs-c:jar:1.6.0-RC2
        2) org.geotools:gt2-fm:jar:2.4-SNAPSHOT
2) org.geotools:gt2-community-schema-ds:jar:2.4-SNAPSHOT
-DartifactId=gt2-community
-schema-ds -Dversion=2.4-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
there:
-DartifactId=gt2-community-s
-Durl=[url]
-DrepositoryId=[id]
  Path to dependency:
2 required artifacts are missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  ibiblio (http://www.ibiblio.org/maven2),
  refractions (http://lists.refractions.net/m2/),
  espace (http://maven.espace.ird.nc),
  Sateh (http://maven.sateh.com/repository),
  skynet.be (http://maven2.mirrors.skynet.be/pub/maven2),
  mortbay (http://www.mortbay.org/maven2/release),
  geotools (http://maven.geotools.fr/repository/)
[INFO]
[INFO]
[INFO] Total time: 11 minutes 59 seconds
[INFO] Finished at: Mon Jan 14 03:06:35 GMT 2008
[INFO] Final Memory: 27M/48M
[INFO]
It appears that two jar files are missing. But when I tried to download
these jar files using a web browser, they didnt appear to exist in any of
the repositories listed above.
Any suggestions anyone? Please!
Arif
View this message in context: http://www.nabble.com/Problem-installing-community-schema-branch-tp14800939p14800939.html
Hi Arif, it seems just to be that the gt2-fm artifact was not installed with
the gt build. Did you use -Ppending when building geotools?
Try the following under the geotools root source tree:
cd modules/unsupported/community-schema
mvn clean install
that should build and install the required community-schema artifacts on your
local maven repo. Then go back to building geoserver 1.6.x
hope that helps,
Gabriel
branch as provided at
http://docs.codehaus.org/display/GEOS/Complex+Datastore. I have been able
to execute first step successfully, i.e. installing geotools. However, when
trying to install geoserver source code I get the following error:
[INFO]
[ERROR] BUILD ERROR
[INFO]
Missing:
-Dvers
there:
-Dversio
-DrepositoryId=[
id]
  Path to dependency:
there:
-Durl=[url]
-DrepositoryId=[id]
  Path to dependency:
for artifact:
[INFO]
[INFO]
[INFO]
Arif
