[Geoserver-users] Problem installing community schema
I have been trying to follow the updated instructions for installing
community schema as given at:
http://docs.codehaus.org/display/GEOS/Complex+Datastore
But I am running into the following problems:
When checking out the geotools source code:
$svn co http://svn.geotools.org/geotools/branches/2.4.x
Error: svn: PROPFIND request failed on '/geotools/branches/2.4.x'
svn: PROPFIND of '/geotools/branches/2.4.x': could not connect to server
(http://svn.geotools.org)
Similar problem when trying to check out the geoserver source code:
Fetching external item into
'1.6.x\geoserver\community\community-schemas\web-c\m
inimal'
svn: PROPFIND request failed on '/geoserver/trunk/configuration/minimal'
svn: PROPFIND of '/geoserver/trunk/configuration/minimal': could not connect
to server (http://svn.codehaus.org)
Could anyone help please??
Regards
Arif
View this message in context: http://www.nabble.com/Problem-installing-community-schema-tp14714139p14714139.html
