[Geoserver-users] Problem installing geoserver 2.0 alpha
When I try to install Geoserver 2.0a release, I get he following error:
0 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger@…2380… via org.mortbay.log.Slf4jLog
250 [main] WARN org.mortbay.log - Deprecated configuration used for C:\Program Files\GeoServer 2.0-beta1/webapps
282 [main] INFO org.mortbay.log - jetty-6.1.8
log4j:WARN File option not set for appender [logfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
03 jun 19:35:46 WARN [geoserver.logging] - Could not find configuration file for logging
log4j:ERROR No output stream or file set for the appender named [logfile].
1532 [main] INFO /geoserver - Initializing Spring root WebApplicationContext
03 jun 19:35:47 INFO [context.ContextLoader] - Root WebApplicationContext: initialization started
03 jun 19:35:47 INFO [support.XmlWebApplicationContext] - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@anonymised.com: display name [Root WebApplicationContext]; startup date [Wed Jun 03 19:35:47 CEST 2009]; root of context hierarchy
03 jun 19:35:47 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/gwc-2.0-beta1.jar!/applicationContext.xml]
03 jun 19:35:47 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/main-2.0-beta1.jar!/applicationContext.xml]
03 jun 19:35:47 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/wcs-2.0-beta1.jar!/applicationContext.xml]
03 jun 19:35:47 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/wcs1_1-2.0-beta1.jar!/applicationContext.xml]
03 jun 19:35:47 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/web-core-2.0-beta1.jar!/applicationContext.xml]
03 jun 19:35:47 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/web-demo-2.0-beta1.jar!/applicationContext.xml]
03 jun 19:35:47 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/web-wcs-2.0-beta1.jar!/applicationContext.xml]
03 jun 19:35:47 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/web-wfs-2.0-beta1.jar!/applicationContext.xml]
03 jun 19:35:47 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/web-wms-2.0-beta1.jar!/applicationContext.xml]
03 jun 19:35:47 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/wfs-2.0-beta1.jar!/applicationContext.xml]
03 jun 19:35:47 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/wms-2.0-beta1.jar!/applicationContext.xml]
03 jun 19:35:47 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/main-2.0-beta1.jar!/applicationSecurityContext.xml]
03 jun 19:35:47 INFO [support.XmlWebApplicationContext] - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
03 jun 19:35:47 INFO [support.XmlWebApplicationContext] - Bean ‘resourceLoader’ is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
03 jun 19:35:47 ERROR [geoserver.global] -
  • GEOSERVER_DATA_DIR: C:\Program Files\GeoServer 2.0-beta1\webapps\geoserver\data
03 jun 19:35:47 INFO [support.DefaultListableBeanFactory] - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [gwcAppCtx,gwcXmlConfig,gwcGSConfig,gwcTLDispatcher,gwcDefaultStorageFinder,gwcMetaStore,gwcBlobStore,gwcStorageBroker,geowebcacheDispatcher,gwcServiceWMS,gwcServiceGMaps,gwcServiceMGMaps,gwcServiceVE,gwcServiceKML,gwcServiceWFS,gwcSeederThreadPoolExec,gwcSeedRestlet,gwcSeedFormRestlet,gwcReloadRestlet,gwcTileLayerRestlet,gwcRestDispatcher,gwcProxyDispatcher,gwcUrlMapping,gwcCatalogListener,resourceLoader,extensions,rawCatalog,secureCatalog,geoServer,geoServerLoader,serviceStrategyFactory,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy2,customEditorConfigurer,dispatcher,filePublisher,jaiInitializer,loggingInitializer,defaultDataSecurityFactory,defaultCatalogSecurityFactory,disabledServiceChecker,dispatcherMapping,legacyWcsLoader,wcsLoader,wcsAbstractService,wcsService,wcsGetCapabilities,wcsDescribeCoverage,wcsGetCoverage,wcsService2,wcsServiceDescriptor,wcsExceptionHandler,wcsGetCapabilitiesKvpReader,describeCoverageKvpReader,getCoverageKvpReader,wcsXmlReader,wcsGetCapabilitiesXmlReader,describeCoverageXmlReader,getCoverageXmlReader,wcsGetCapabilitiesResponse,describeCoverageResponse,getCoverageResponse,wcsURLMapping,wcs111ServiceTarget,wcsLogger,wcs111Service,wcsService-1.1.0,wcsService-1.1.1,wcs111URLMapping,wcs111ExceptionHandler,ows11AcceptVersionsKvpParser,ows11SectionsKvpParser,wcs111RangeSubsetKvpParser,wcs111IdentifierKvpParser,wcs111BoundingBoxKvpParser,wcs111GridBaseCRSKvpParser,wcs111TimeSequenceKvpParser,wcs111GridTypeKvpParser,wcs111GridCSKvpParser,wcs111GridOriginKvpParser,wcs111GridOffsetsKvpParser,wcs111GetCapabilitiesKvpReader,wcs111DescribeCoverageKvpReader,wcs111GetCoverageRequestReader,wcs111StoreKvpParser,wcs-1.1.1-configuration,wcs111CapabilitiesRequestReader,wcs111DescribeCoverageRequestReader,wcs111GetCoverageRequestXMLReader,wcs111GetCapabilitiesResponse,wcs111DescribeCoverageResponse,wcs111GetCoverageMultipartResponse,wcs111GetCoverageStoreResponse,wcs111DispatcherMapping,wcs111TempStorageCleaner,wcs111TempStorageCleanerTask,wcs111timerFactory,webApplication,wicket,webDispatcherMapping,serverCategory,dataCategory,servicesCategory,statusMenuPage,contactMenuPage,globalSettingsMenuPage,JAIMenuPage,abountMenuPage,workspaceMenuPage,storeMenuPage,layerMenuPage,layerGroupMenuPage,demoMenuPage,basicResourceConfigPanel,featureResourceConfigPanel,coverageResourceConfigPanel,basicLayerConfigPanel,httpLayerConfigPanel,defaultDataStorePanel,defaultCoverageStorePanel,postgisDataStorePanel,shapefileDataStorePanel,propertyDataStorePanel,wfsDataStorePanel,layerListDemo2,demoRequests,srsList,wcsServicePage,wcsLayerConfig,wfsServicePage,wfsLayerConfig,wmsServicePage,wmsLayerConfig,geosearchLayerConfig,kmlLayerConfig,styleMenuPage,filterFactory,wfsLegacyLoader,wfsLoader,wfsServiceTarget,wfsLogger,wfsService,wfsInsertElementHandler,wfsUpdateElementHandler,wfsDeleteElementHandler,wfsNativeElementHandler,wfsService-1.0.0,wfsService-1.1.0,wfsExceptionHandler,gml2SchemaBuilder,gml3SchemaBuilder,wfsXsd-1.0,xmlConfiguration-1.0,wfsXsd-1.1,xmlConfiguration-1.1,getCapabilitiesResponse,lockFeatureResponse,transactionResponse-1.0.0,geometryResponse,featureResponse,citeComplianceHack,wfsURLMapping,typeNameKvpParser,featureIdKvpParser,bboxKvpParser,filter1_0_0_KvpParser,filter1_1_0_KvpParser,filter1_1_0_KvpParserDefault,cqlKvpParser,propertyNameKvpParser,maxFeatureKvpParser,srsNameKvpParser,sortByKvpParser,expiryKvpParser,resultTypeKvpParser,acceptVersionsKvpParser,acceptFormatsKvpParser,strictKvpParser,wfsFormatOptionsKvpParser,charsetKvpParser,wfsGetCapabilitiesKvpReader,describeFeatureTypeKvpReader,getFeatureKvpReader,getFeatureWithLockKvpReader,lockFeatureKvpReader,transactionKvpReader,releaseLockKvpReader,xmlReader-1.0.0,wfsGetCapabilitiesXmlReader,describeFetureTypeXmlReader,getFeatureXmlReader,getFeatureWithLockXmlReader,lockFeatureXmlReader,transactionXmlReader,xmlReader-1.1.0,wfsGetCapabilitiesXmlReader-1.1.0,describeFeatureTypeXmlReader-1.1.0,getFeatureTypeXmlReader-1.1.0,getFeatureWithLockXmlReader-1.1.0,lockFeatureXmlReader-1.1.0,transactionXmlReader-1.1.0,getGmlObjectXmlReader-1.1.0,gml2FeatureTypeEncoder,gml3FeatureTypeEncoder,gml2OutputFormat,gml3OutputFormat,hitsOutputFormat,shapezipOutputFormat,geojsonOutputFormat,CSVOutputFormat,wmsLegacyLoader,wmsLoader,wms,wmsRegisterar,wmsGetCapabilities,wmsDescribeLayer,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsService2,wmsServiceDescriptor,wmsExceptionHandler,widthKvpParser,heightKvpParser,wmsFormatOptionsKvpParser,bgColorKvpParser,transparentKvpParser,tiledKvpParser,tilesOriginKvpParser,bufferKvpParser,paletteKvpParser,timeKvpParser,elevationKvpParser,validateSldKvpParser,sldKvpParser,startIndexKvpParser,wmsGetCapabilitiesKvpReader,describeLayerKvpReader,getMapKvpReader,getFeatureInfoKvpReader,getLegendGraphicKvpReader,wmsCapabilitiesXmlReader,getMapXmlReader,sldXmlReader,wmsGetCapabilitiesResponse,describeLayerResponse,getMapResponse,getFeatureInfoResponse,getLegendGraphicResponse,wmsURLMapping,GIFLegendProducerFactory,JaiLegendProducerFactory,PNGLegendProducerFactory,PNGMapProducer,GeoTiffMapProducer,TiffMapProducer,GIFMapProducer,JPEGMapProducer,PDFMapProducerFactory,KMLMapProducer,KMZMapProducer,OpenLayersMapProducer,AtomGeoRSSMapProducer,RSSGeoRSSMapProducer,SVGMapProducer,kmlService,kmlServiceDescriptor,kmlURLMapping,superOverlayKvpParser,legendKvpParser,kmatrrKvpParser,kmscoreKvpParser,kmplacemarkKvpParser,metaTileCache,nativeSortingRegionator,externalSortingRegionator,geometryRegionator,randomRegionator,bestGuessRegionator,image,legend,scaleratio,scaleline,filterChainProxy,restFilterInvocationInterceptor,restFilterDefinitionMap,filterInvocationInterceptor,httpSessionContextIntegrationFilterWithASCTrue,httpSessionContextIntegrationFilterWithASCFalse,logoutFilter,authenticationProcessingFilter,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,basicProcessingFilter,basicProcessingFilterEntryPoint,consoleExceptionTranslationFilter,owsExceptionTranslationFilter,rememberMeServices,authenticationManager,daoAuthenticationProvider,userDetailsService,accessRulesDao,operationSecurityInterceptor]; root of factory hierarchy
03 jun 19:35:47 INFO [util.ApplicationContextProvider] - No context parameter, system or Java environment variables found for GEOSERVER_WMS_URL
03 jun 19:35:47 INFO [util.ApplicationContextProvider] - Reverting to http://localhost:8080/geoserver/wms?request=GetCapabilities
03 jun 19:35:47 INFO [util.GetCapabilitiesConfiguration] - Constructing from url http://localhost:8080/geoserver/wms?request=GetCapabilities
03 jun 19:35:48 INFO [support.DefaultListableBeanFactory] - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [gwcAppCtx,gwcXmlConfig,gwcGSConfig,gwcTLDispatcher,gwcDefaultStorageFinder,gwcMetaStore,gwcBlobStore,gwcStorageBroker,geowebcacheDispatcher,gwcServiceWMS,gwcServiceGMaps,gwcServiceMGMaps,gwcServiceVE,gwcServiceKML,gwcServiceWFS,gwcSeederThreadPoolExec,gwcSeedRestlet,gwcSeedFormRestlet,gwcReloadRestlet,gwcTileLayerRestlet,gwcRestDispatcher,gwcProxyDispatcher,gwcUrlMapping,gwcCatalogListener,resourceLoader,extensions,rawCatalog,secureCatalog,geoServer,geoServerLoader,serviceStrategyFactory,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy2,customEditorConfigurer,dispatcher,filePublisher,jaiInitializer,loggingInitializer,defaultDataSecurityFactory,defaultCatalogSecurityFactory,disabledServiceChecker,dispatcherMapping,legacyWcsLoader,wcsLoader,wcsAbstractService,wcsService,wcsGetCapabilities,wcsDescribeCoverage,wcsGetCoverage,wcsService2,wcsServiceDescriptor,wcsExceptionHandler,wcsGetCapabilitiesKvpReader,describeCoverageKvpReader,getCoverageKvpReader,wcsXmlReader,wcsGetCapabilitiesXmlReader,describeCoverageXmlReader,getCoverageXmlReader,wcsGetCapabilitiesResponse,describeCoverageResponse,getCoverageResponse,wcsURLMapping,wcs111ServiceTarget,wcsLogger,wcs111Service,wcsService-1.1.0,wcsService-1.1.1,wcs111URLMapping,wcs111ExceptionHandler,ows11AcceptVersionsKvpParser,ows11SectionsKvpParser,wcs111RangeSubsetKvpParser,wcs111IdentifierKvpParser,wcs111BoundingBoxKvpParser,wcs111GridBaseCRSKvpParser,wcs111TimeSequenceKvpParser,wcs111GridTypeKvpParser,wcs111GridCSKvpParser,wcs111GridOriginKvpParser,wcs111GridOffsetsKvpParser,wcs111GetCapabilitiesKvpReader,wcs111DescribeCoverageKvpReader,wcs111GetCoverageRequestReader,wcs111StoreKvpParser,wcs-1.1.1-configuration,wcs111CapabilitiesRequestReader,wcs111DescribeCoverageRequestReader,wcs111GetCoverageRequestXMLReader,wcs111GetCapabilitiesResponse,wcs111DescribeCoverageResponse,wcs111GetCoverageMultipartResponse,wcs111GetCoverageStoreResponse,wcs111DispatcherMapping,wcs111TempStorageCleaner,wcs111TempStorageCleanerTask,wcs111timerFactory,webApplication,wicket,webDispatcherMapping,serverCategory,dataCategory,servicesCategory,statusMenuPage,contactMenuPage,globalSettingsMenuPage,JAIMenuPage,abountMenuPage,workspaceMenuPage,storeMenuPage,layerMenuPage,layerGroupMenuPage,demoMenuPage,basicResourceConfigPanel,featureResourceConfigPanel,coverageResourceConfigPanel,basicLayerConfigPanel,httpLayerConfigPanel,defaultDataStorePanel,defaultCoverageStorePanel,postgisDataStorePanel,shapefileDataStorePanel,propertyDataStorePanel,wfsDataStorePanel,layerListDemo2,demoRequests,srsList,wcsServicePage,wcsLayerConfig,wfsServicePage,wfsLayerConfig,wmsServicePage,wmsLayerConfig,geosearchLayerConfig,kmlLayerConfig,styleMenuPage,filterFactory,wfsLegacyLoader,wfsLoader,wfsServiceTarget,wfsLogger,wfsService,wfsInsertElementHandler,wfsUpdateElementHandler,wfsDeleteElementHandler,wfsNativeElementHandler,wfsService-1.0.0,wfsService-1.1.0,wfsExceptionHandler,gml2SchemaBuilder,gml3SchemaBuilder,wfsXsd-1.0,xmlConfiguration-1.0,wfsXsd-1.1,xmlConfiguration-1.1,getCapabilitiesResponse,lockFeatureResponse,transactionResponse-1.0.0,geometryResponse,featureResponse,citeComplianceHack,wfsURLMapping,typeNameKvpParser,featureIdKvpParser,bboxKvpParser,filter1_0_0_KvpParser,filter1_1_0_KvpParser,filter1_1_0_KvpParserDefault,cqlKvpParser,propertyNameKvpParser,maxFeatureKvpParser,srsNameKvpParser,sortByKvpParser,expiryKvpParser,resultTypeKvpParser,acceptVersionsKvpParser,acceptFormatsKvpParser,strictKvpParser,wfsFormatOptionsKvpParser,charsetKvpParser,wfsGetCapabilitiesKvpReader,describeFeatureTypeKvpReader,getFeatureKvpReader,getFeatureWithLockKvpReader,lockFeatureKvpReader,transactionKvpReader,releaseLockKvpReader,xmlReader-1.0.0,wfsGetCapabilitiesXmlReader,describeFetureTypeXmlReader,getFeatureXmlReader,getFeatureWithLockXmlReader,lockFeatureXmlReader,transactionXmlReader,xmlReader-1.1.0,wfsGetCapabilitiesXmlReader-1.1.0,describeFeatureTypeXmlReader-1.1.0,getFeatureTypeXmlReader-1.1.0,getFeatureWithLockXmlReader-1.1.0,lockFeatureXmlReader-1.1.0,transactionXmlReader-1.1.0,getGmlObjectXmlReader-1.1.0,gml2FeatureTypeEncoder,gml3FeatureTypeEncoder,gml2OutputFormat,gml3OutputFormat,hitsOutputFormat,shapezipOutputFormat,geojsonOutputFormat,CSVOutputFormat,wmsLegacyLoader,wmsLoader,wms,wmsRegisterar,wmsGetCapabilities,wmsDescribeLayer,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsService2,wmsServiceDescriptor,wmsExceptionHandler,widthKvpParser,heightKvpParser,wmsFormatOptionsKvpParser,bgColorKvpParser,transparentKvpParser,tiledKvpParser,tilesOriginKvpParser,bufferKvpParser,paletteKvpParser,timeKvpParser,elevationKvpParser,validateSldKvpParser,sldKvpParser,startIndexKvpParser,wmsGetCapabilitiesKvpReader,describeLayerKvpReader,getMapKvpReader,getFeatureInfoKvpReader,getLegendGraphicKvpReader,wmsCapabilitiesXmlReader,getMapXmlReader,sldXmlReader,wmsGetCapabilitiesResponse,describeLayerResponse,getMapResponse,getFeatureInfoResponse,getLegendGraphicResponse,wmsURLMapping,GIFLegendProducerFactory,JaiLegendProducerFactory,PNGLegendProducerFactory,PNGMapProducer,GeoTiffMapProducer,TiffMapProducer,GIFMapProducer,JPEGMapProducer,PDFMapProducerFactory,KMLMapProducer,KMZMapProducer,OpenLayersMapProducer,AtomGeoRSSMapProducer,RSSGeoRSSMapProducer,SVGMapProducer,kmlService,kmlServiceDescriptor,kmlURLMapping,superOverlayKvpParser,legendKvpParser,kmatrrKvpParser,kmscoreKvpParser,kmplacemarkKvpParser,metaTileCache,nativeSortingRegionator,externalSortingRegionator,geometryRegionator,randomRegionator,bestGuessRegionator,image,legend,scaleratio,scaleline,filterChainProxy,restFilterInvocationInterceptor,restFilterDefinitionMap,filterInvocationInterceptor,httpSessionContextIntegrationFilterWithASCTrue,httpSessionContextIntegrationFilterWithASCFalse,logoutFilter,authenticationProcessingFilter,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,basicProcessingFilter,basicProcessingFilterEntryPoint,consoleExceptionTranslationFilter,owsExceptionTranslationFilter,rememberMeServices,authenticationManager,daoAuthenticationProvider,userDetailsService,accessRulesDao,operationSecurityInterceptor]; root of factory hierarchy
03 jun 19:35:48 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: java.lang.NullPointerException
03 jun 19:35:48 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcTLDispatcher’ defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/gwc-2.0-beta1.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘gwcCatalogListener’ while setting bean property ‘config’ with key [0]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcCatalogListener’ defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/gwc-2.0-beta1.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘rawCatalog’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘rawCatalog’ defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/main-2.0-beta1.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveManagedList(BeanDefinitionValueResolver.java:287)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:126)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcCatalogListener’ defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/gwc-2.0-beta1.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘rawCatalog’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘rawCatalog’ defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/main-2.0-beta1.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
… 42 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘rawCatalog’ defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/main-2.0-beta1.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:480)
… 57 more
Caused by: java.lang.RuntimeException: java.lang.NullPointerException
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:127)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
… 66 more
Caused by: java.lang.NullPointerException
at org.geoserver.config.GeoServerLoader.list(GeoServerLoader.java:821)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:459)
at org.geoserver.config.GeoServerLoader.loadCatalog(GeoServerLoader.java:153)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:124)
… 69 more
2594 [main] ERROR org.mortbay.log - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@anonymised.com{/geoserver,file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/}
… 42 more
… 57 more
… 66 more
… 69 more
2719 [main] ERROR org.mortbay.log - Nested in org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcTLDispatcher’ defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/gwc-2.0-beta1.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘gwcCatalogListener’ while setting bean property ‘config’ with key [0]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcCatalogListener’ defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/gwc-2.0-beta1.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘rawCatalog’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘rawCatalog’ defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/main-2.0-beta1.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException:
2844 [main] INFO org.mortbay.log - Opened C:\Program Files\GeoServer 2.0-beta1\logs\2009_06_03.request.log
2875 [main] INFO org.mortbay.log - Started SelectChannelConnector@anonymised.com:8080
Can anyone tell me what to do ?
/artin
Do you mean beta1? The data directory reported on startup points to a geoserver beta1 install. Just to rule it out, is this being run on top of a previous installation?
0 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger@anonymised.com via org.mortbay.log.Slf4jLog
03 jun 19:35:47 INFO [support.XmlWebApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
- GEOSERVER_DATA_DIR: C:\Program Files\GeoServer 2.0-beta1\webapps\geoserver\data
03 jun 19:35:48 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name 'geoServerLoader': java.lang.NullPointerException
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcTLDispatcher' defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/gwc-2.0-beta1.jar!/applicationContext.xml]: Cannot resolve reference to bean 'gwcCatalogListener' while setting bean property 'config' with key [0]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcCatalogListener' defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/gwc-2.0-beta1.jar!/applicationContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/main-2.0-beta1.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcCatalogListener' defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/gwc-2.0-beta1.jar!/applicationContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/main-2.0-beta1.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException
        ... 42 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/main-2.0-beta1.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException
        ... 57 more
        ... 66 more
        ... 69 more
        ... 42 more
        ... 57 more
        ... 66 more
        ... 69 more
2719 [main] ERROR org.mortbay.log - Nested in org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcTLDispatcher' defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/gwc-2.0-beta1.jar!/applicationContext.xml]: Cannot resolve reference to bean 'gwcCatalogListener' while setting bean property 'config' with key [0]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcCatalogListener' defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/gwc-2.0-beta1.jar!/applicationContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/C:/Program%20Files/GeoServer%202.0-beta1/webapps/geoserver/WEB-INF/lib/main-2.0-beta1.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException:
2875 [main] INFO org.mortbay.log - Started SelectChannelConnector@anonymised.com:8080 <http://SelectChannelConnector@anonymised.com:8080>
/artin
OpenSolaris 2009.06 is a cutting edge operating system for enterprises looking to deploy the next generation of Solaris that includes the latest innovations from Sun and the OpenSource community. Download a copy and enjoy capabilities such as Networking, Storage and Virtualization. Go to: http://p.sf.net/sfu/opensolaris-get
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
